Old 21st March 2018, 08:39 PM
Sealey VS70095
Its discontinued now which is odd. Plenty on ebay though.
The car has to be level to fill the gearbox and you need good access underneath it so it really needs to be on a lift, but you also need to get to VCDS to monitor the gearbox temperature so it can't be all the way up in the air (unless you have a USB extension maybe?). I tend to do it about 4" up in the air so I can still see the laptop but there's room to work underneath. I don't think you would be successful trying to do it on axle stands.
That's got me thinking now - it might be possible to fashion a contrivance which would replace the oil in the radiator before you put the top line back on, then you don't need to mess around underneath. Hmm...
Old 22nd March 2018, 02:23 AM
27litres's Avatar
27litres 27litres is offline
That's exactly what I did when replacing my radiator .
I put the bottom trans line on, then used a 20ml syringe (just because it was the size I had in the first aid kit) with a 6" piece of vac hose on the end to add some fresh ATF in the top hole until that was full and put the top line on. No worries!
We just used an infrared gun type thermometer and monitored the trans sump temp.
We weren't too critical about the process though...
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 22nd March 2018, 08:20 AM
Excellent That's exactly what I came up with while I couldn't sleep last night! Glad to know it works
