D3 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Just had a play with VCDS
I'd cleared the error code before the MOT, but i just did a readiness test and it passed everything apart from the Cats, so 0000 0001 It seemed to think the sensors with the aging test was ok Blocks 46 and 47 read Cat 0.13 and 0.19 I've got some Toluene and half a tank of gas, so i'll go for a drive and see if I get any real change. I had a cat issue with an Rx8 I have and on swapping, found the housing empty....Am wondering with an inspection camera if you could feed it down the exhaust or maybe break the pipe and do a visual inspection???
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
