Old 11th August 2010, 05:36 AM
I think Ians right - as someone who has just changed his box it sounds like youve lost a clutch basket so youre not getting past 3rd gear. . . sorry to hear
Old 11th August 2010, 05:55 AM
EcosseV8
Guest
Posts: n/a
Just a thought -any chance these symptoms and fault codes could be caused by a faulty F125 switch???
Old 11th August 2010, 07:29 AM
You mention 5th gear, and 1997 which makes this one of the 'deadly DTD' type gearboxes, the first of the 5 speed quattros.....
You dont mention your mileage, but if its anything like 125000 + then statistically its likely the box is dead. Any garage that takes your money for a fluid change at this point is just robbing you tbh....
Old 11th August 2010, 02:31 PM
From Ross Tech Wiki if this helps -
17118/P0734 - Gear 4: Incorrect Ratio
Possible Causes
Wiring and/or connections faulty
Sensor Gear Position Indicator faulty
Gear Solenoides faulty
Mechanical failure
Possible Solutions
Check wiring and connections
Check Sensor Gear Position Indicator
Check Gear Solenoides
17119/P0735/001845 - Gear 5: Incorrect Ratio
Possible Symptoms
Clutch Slipping
Reduced Power Output
Possible Causes
Gear related Clutch slipping/faulty
Gear related Solenoid Valve dirty/faulty
Overloaded Clutch due to continuous high Torque or Tuning
Wiring and/or Connections faulty
Mechanical Failure
Possible Solutions
Check Engine Values for Plausibility, especially Torque related ones.
Check Wiring and Connections
Special Notes
The gear monitoring of the transmission control module checks the gear ratio by comparing transmission input and output speed in regard of the currently selected gear. This fault code is being set when recognizing an implausible transmission ratio.
17114/P0730/001840 - Gear Ratio Monitoring: Incorrect Gear Ratio
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Transmission Fluid contaminated
Transmission faulty (Mechanical Problem)
Possible Solutions
Check Transmission Fluid (Color and Contamination)
Replace Transmission Fluid when necessary
Check Transmission Mechanics
Special Notes
Transmission Damage may be caused by Engine Problems, make sure there are no other/relevant Fault Codes stored in Engine Control Module.
17087/P0703/001795 - Brake Switch (F): Electrical Malfunction
Possible Symptoms
Possible Causes
Wiring and/or Connector(s) from/to Brake Switch (F) faulty
Possible Solutions
Check Wiring and/or Connector(s) from/to Brake Switch (F)
Check/Replace Brake Switch (F)
Special Notes
When found in Vehicles with Drive-by-Cable (DBC) the Brake Switch (F) is connected to the Transmission Control Module. On older Models this Code is stored automatically after Terminal 15/Ignition is switched ON. If the Brake Switch (F) is OK you can avoid this Fault Code by pressing the Brake Pedal after switching on the Ignition and prior to checking Fault Codes. The Code should automatically be cleared then.
When found in Vehicles with Drive-by-Wire (DBW) the Brake Switch (F) is connected to the Engine Control Module In this case you should check the Engine Control Module for Fault Codes as well and the Data Bus Wiring between Engine and Transmission Control Module.
Old 11th August 2010, 08:53 PM
EcosseV8
Guest
Posts: n/a
Default Bad news.....
As feared the gearbox is toast. I've decided to cut my losses and call it a day, so if anyone is in the market for a 1997 4.2 QS (pre FL) with 149K on the clock for spares or repair I'm open to offers (collection only!!). Car is in excellent condition for year bar the knackered gearbox (pics available).
Gutted at this outcome but c'est la vie.....if someone is willing to either take on a project or spend £1500 on a gearbox overhaul then they will have themselves a great car. Otherwise its up for spares/breaking.
Old 11th August 2010, 09:04 PM
What sort of money you looking for? I could be interested but reckon you would make a lot more as spares/repairs if you can be bothered with the effort and time. Colour/Spec?
Old 11th August 2010, 10:41 PM
EcosseV8
Guest
Posts: n/a
Sorry for the delay but will get back to you tomorrow once I have a better idea of what I'm looking for.... only found out the position with the car today. I'll be taking my refurbed Robal alloys (swapping them with those on my dad's A8) and the 6-CD changer, but everything else will stay with the car. Alas I don't have the time to break up the car for spares myself.
