Alex. This issue can happen when clearing error codes too, it is advisable to go into the specific module in question and clear it manually.
Saying that, sometimes it isn’t necessary.
Thanks
I'm assuming then I need some values to enter to create a reminder at an appropriate point? I'll do some more googling. Cheers Alex |
I don’t have encyclopaedic knowledge of VCDS, but is there a channel called Instrument Cluster, which you can click into and have a play with?
Sure someone will be along soon to offer more help than I.
However, sometimes it doesn't seem to work! But if you run the VCDS SRI function, even if you don't change anything, VCDS stores the current values in the VCDS Debug folder. See an example from my 3.0 TDi attached. If you could look at yours and enter it here, we can probably help you ... Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
