Old 19th April 2018, 04:09 PM
these drains are a right pain.
last time I had it I took the carpets out.
not a bad job and left them in the sun to dry while the carpets were out it was a lot easier to dry the floor below.
I also had to remove them for the aircon drains as well once so if you got wet carpets I might recommend whipping them out and cleaning the aircon drains at the same time.
Old 19th April 2018, 04:18 PM
It takes ages to dry out the front carpets so get them out of the car, left inside they could be damp for weeks!
Not much under the drivers feet to be honest, mostly ventilation ducts and a bit of wiring.
Old 19th April 2018, 04:32 PM
Simonbartlett Simonbartlett is offline
Cat litter in trays or inside tights absorbs smells and moisture ! Just font leave the doors open or all the local cats will be in there 😁
Owner of a 2008 A8 3.0tdi SE
Old 19th April 2018, 04:47 PM
Inside a pair of tights? I don't want to know how you know that!
