Yes it can - and has done to my D3 - or at least the ABS and ESP lights part can be (I think that the Headlight range and Parking brake may well be seperate faults)
and the brake switch isn't too expensive or difficult to change so I'd definitely start with that first ![]() Your adaptive cruise won't work of there is known issues with the ABS and ESP for safety reasons I would have thought
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 24th April 2018 at 07:48 AM. |
I agree with Neil, first stop would be VCDS scan to see what errors are logged as brake switch defects will be logged in that
Del ![]() |
I've got an old dodgy copy of vcds, I'll try and scan the car later and post the results.
I wouldn't be certain about the brake switch, when mine went the gearbox went into limp mode. I drove it to the garage thinking the gearbox was toast. I was thrilled to be told it just needed a brake switch.
Today I finally got around to scanning the car. Sorry i am not Beulieu, I've got a job application to finish off and my CV as unemployment looms.
I have attached the log, but aside from the usual issues my D3 has and those relating to low battery as the car is hardly used one stands out like a sore thumb. Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 A Component: ESP 5.7 allrad H29 0420 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 214DE1B78159 1 Fault Found: 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 012 - Electrical Fault in Circuit - Intermittent That is the obvious stand out, how easy is that sensor to sort or check the wiring connections? Perhaps if someone else could review the whole log I would feel happier. With the fault present I can clear the ABS sensor fault but as soon as you close the controller it returns. However after the car has gone fully to sleep the fault is no longer current and will drive fine again until it recurs.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 29th April 2018 at 11:07 AM. |
Well as you suspect I'd say most of that will clear ok other than the abs sensor and level control pressure and temp warning I would be too concerned.
the abs sensor may be faulty but worth checking the contacts for grime or corrosion. The door handles quite possibly are dragging down the battery. The rear parking sensor can be changed assuming its it at fault without removing the bumper, well it can be on the S8 bumper. Once you sort the the abs out the headlight and acc should start behaving too.
Del ![]() |
Wheel bearing?
