Old 11th May 2018, 12:19 PM
Thanks Guys.
Jim, photos would be appreciated if you have any!
The main reason I was looking at 20mm all round (apart from simplicity/consistency) was that the 20mm spacers are the type that bolt on to the hub. It seems that spacers less than 20mm use longer through-bolts instead (presumably because the spacer is too thin to securely bolt a wheel to).
Or have I got that wrong?
