Old 20th May 2018, 10:42 PM
I'm not sure that Sergey is coming to the annual meet this year?
He might be coming to Germany possibly.
I think I'm right in saying that the colour of the plastic on the RNSe isn't an exact match to the ventilation controls next to it below. Unless of course you prise the only known perfectly matching ventilation controls from my cold dead fingers or make me an outrageously good offer!!
Old 21st May 2018, 07:22 AM
I never found the difference noticeable enough to worry about - after all the matching wood trims on doors and dash are nowhere near the same finish!
I think Kiwi shoe polish or similar does the job to darken it but prob best done with trim off the unit!
Another thing to add - early units will most likely have weak lasers so will only work with OEM discs. I’ve posted how to change the nav transport before - not difficult and will then continue working with copy discs
Old 22nd May 2018, 06:43 AM
Spanker's Avatar
Spanker Spanker is offline
So how come you've got the only matching set of dash trims known?
And why do you have them? What's the back story?
I can't recall seeing an RNS-E in your 3.7?
Dean
Old 22nd May 2018, 01:09 PM
1. Because I bought the matching HVAC unit from Amanda on here (misano red RS6) who had them previously and I think that prior to that IT or David had it on a specific car and stated that it was the only matching unit he'd ever seen
2. Because I always planned to upgrade to an RNS-e one day so my OCD told me to buy the matching unit
3. No still not done that yet because at the time Sergey and a guy from Norway or Sweden were trying to decipher the coding to get the DIS to work correctly which would have again pleased my OCD!
Old 13th October 2019, 04:20 PM
Ronin Ronin is offline
How did you go about altering the taper so it matches the center console? I reckon sanding it down is the most accurate and least destructive way of doing it?
Old 16th October 2019, 09:29 PM
Er, post 27 of this very thread ?
Old 16th January 2020, 06:37 PM
Pcbbc Pcbbc is offline
So what’s the status with this? From reading the thread it appears it doesn’t work at all for the turn directions on the centre section. Am I correct? I’m fairly sure it should be fixable....
An RNS-E almost works in an 8N TT, for which it was never designed. The MK1 TT only had an even earlier Nav system from the factory, a BNS3.0 or 4.0
Here’s the before and after video of the firmware fix I did to make RNS-E work for that platform....
https://youtu.be/WAzD-N909Mo
So someone may want to get in touch?
I would suggest a PM is best. Or contact me as user pcbbc over at the ttforum.co.uk (although I have subscribed to this thread, so hopefully I will see any replies).
Old 18th January 2020, 12:08 PM
Its been talked about for a good decade or so now.... The problem is that it isn't easy, and the solution is in far less demand than it was back then making a solution less likely to ever be engineered.
The issue, as far as I'm aware is that the DIS in the D2 is an odd resolution. Its full colour, and a different size, relative to all the other cars like the A3/A4/A6/TT that the RNS-E made its way into. If it were monochrome I think there is a better chance the RNS-E would be able to negotiate a screen rez and display turn by turn on a D2 cluster.
The RNS-E does successfully transmit text data for Radio/CD/MP3 into the top line, so its not like a bad coding config or mismatched canbus signal.
Short of playing man in the middle with the display data and morphing it on the fly onto the screen available, from the screen data presented, i'm not sure how it could be overcome, but if you achieve it it would be very impressive to see.
Old 18th January 2020, 01:38 PM
Okay, thanks for the details. You’re right that probably makes it difficult, but not impossible.
Has anyone documented the protocol for the D2 colour DIS anywhere?
I’ve made a start on the monochrome DIS protocol here...
I don’t have a A8 to be playing with, so can’t investigate myself. Not sure I’m up for getting an A8 cluster and trying to build a test harness unless I know more about what’s involved.
The RNSE firmware has code for communicating with two kombi (cluster) types:
One is called “mono” (fairly obviously monochrome I would assume) in the debug messages. This is the one I’m used to in the 8N/8J TTs.
The other is named “hicol” (maybe hires colour?) and I’ve no idea which model that was used on, or even perhaps NOT used on, but perhaps intended for... any clues?
I realise this is a niche market now, but that’s not the point for me. I’m interested in fixing things, but to do that I’m probably going to need help from someone on the A8 D2 side. I can bring all the necessary RNSE patching experience. I’ve stamped on a huge number of bugs and niggles in the RNSE firmware already, plus a few enhancements along the way.
Old 18th January 2020, 01:50 PM
I can lend you an A8 cluster and wiring to play with if that would help? I am going to be fitting a mk2 RNS-e in to an S8 in the next few months so if you can get the DIS working that would be some very nice icing on the cake
'Hicol' is very likely the colour screen as it was called 'nav high' or 'highline' in some models. I have a B7 with it, and I'm sure that term or something similar appeared in the spec sheet.
