Originally Posted by richardracer
Hi there,
I had 2 of those error codes on my D3 S8, namely engine mounting and ecu code. Neither changed or had an effect for over 100,000 miles. Rear pads easy to check, remove rear wheel and look.
Regards
Richardracer
That's reassuring! Can ceramics be checked in the same way?
Originally Posted by Architex_mA8tey
The Active engine mounting soloniods are not working on most D3's and most people ignore them due to stupid cost and time consuming job to replace them
That's good news. Will try and get the mount checked to ensure it's not shot and if it's ok leave it alone
