D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
Yes, they can be.
They are screwed into the metal and poke through the hole in the trim. You can then screw? the outer body uo/down by hand. It is trial and error. You have to release the centre pin before adjusting because the spring loaded pin is what does the work. I didn't understand this bit and thought that I had wasted my time and money until a clever young smartass pointed it out to me. I only remembered about the adjustment when reading this thread last night, so went out and tried it. Eureka it worked. It does make the release a bit noisy late at night, but it works. Good luck with it.
