Old 23rd June 2018, 01:00 PM
North2007 North2007 is offline
I was able just to confirm the values which were already stored. Which resulted in the level sensor thinking it is calibrated, and showing no faults.
If I take the time to insert the correct values, I only get to the thrid wheel before it shows the error: security access required.
Is it on a timer? Can it be adjusted to allow complete programing 1 to 5?
2003, A8 D3 4.0 TDI
Old 26th June 2018, 06:32 AM
The procedure is very fussy and difficult to complete.
How far are you trying to adjust, the key is to input small differences to the current values and repeat several times until you get it to complete successfully.
Audiworld has a good step by step guide.
https://www.audiworld.com/forums/a8-...tment-2840525/
Old 26th June 2018, 11:00 AM
Conquistador's Avatar
Ensure the car is on a perfectly flat level surface and don't be sitting in the car while you are calibrating the suspension! Have the window open and laptop on the roof or bonnet.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 27th June 2018, 10:05 AM
All four cornerss are at various setting. The worst 40mm lower rear right. Ive been trying it in small steps (15mm). After code one wheel, and I move up to 2, it throws up “ERROR: Security access required”. At which point i have to exit input 31564 begore starting again. Sometimes I get to wheel 4 before the error.
Ive been following the instructions, not in car and level etc.
2003, A8 D3 4.0 TDI
Old 27th June 2018, 10:08 AM
If a genuine cable worth posting on Ross Tech's forum, they are usually very responsive and helpful
Old 27th June 2018, 11:21 AM
Seems like it's loosing connection somewhere in the middle of procedure, then reconnects and you need to enter code again. this is more common with clone cables but sometimes low/weak battery can cause it as well, try connecting battery charger while you do it.
Old 27th June 2018, 11:29 AM
The other thing I've noticed is that if you have any kind of air suspension fault or issue then you will need to ensure all of those issues are fixed first before trying to re-calibrate as it doesnt seem to like calibrating with any kind of known fault
Old 27th June 2018, 11:30 AM
Many thanks all for your help. Ive posted on ross tech forum, ill let you know the outcome.
2003, A8 D3 4.0 TDI
Old 1st August 2019, 07:10 PM
Johnmed's Avatar
Johnmed Johnmed is offline
This.
2007 Mini Cooper S R56
