Old 13th July 2018, 12:33 PM
Conquistador's Avatar
Most likely the heat. The glass is being heated all day long then you jump in and blast the aircon on your face and windows which cools the glass quicker than it ever would naturally. The glass is fighting against two extremes and something has to give eventually under those circumstances.
Must be the heat, my front windscreen cracked for no reason as well last week
Same goes for you. There may have already been a small chip which you didn't notice and the heat and cooling has caused the crack.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 13th July 2018, 11:20 PM
B4-Andy B4-Andy is offline
So it's one of these things I have thought about often in the past few months, suppose you live in the Canaries / North Africa. These cars are tested to survive the environment there, as well as waaaay up north, such as Glasgow or Reykjavík. There are regional specific parts to every car, but the basics of the car should survive between the extremes.
So in theory, I agree the extreme heat might be causing problems, but it doesn't sit right....
Only windscreen I ever had spontaneously crack was in a cabriolet while in a back road blast with a motorbike, went round one corner and hit an odd bump in the road, which caused the car to bounce strangely, like during a left turn the car essentially bounced 2ft to the right (at last that's how it felt). Didn't notice the fracture in the bottom corner of the windscreen until I got back out.
Retro Audi fan! A2 1.6 FSI, Audi Cabrio v6, D2 S8.
Old 14th July 2018, 11:50 AM
I am sure they are tested and only small amount fail due to extreme weather. Also if you have large variations regularly car might get 'used to it' and less likely to fail.
