Old 19th July 2018, 08:58 AM
Proof indeed that higher-intellect aliens have infiltrated our humble human society!
Old 19th July 2018, 09:21 AM
I'm the monster's mother
Old 19th July 2018, 09:51 AM
Someone photoshop that with red hair...……
Old 19th July 2018, 09:46 PM
TDI rear diff:
Original diff in the background
Cleaned up the CV joints and replaced the gaskets
Installed
Sorted the wiring for the reverse switch. New connector and wires to extend the original N75 wires over to the other side of the gearbox
Re-used some sleeving from the autobox harness
Wrapped up with tape and complete. Ideally I would have liked to sleeve all of this, but that would have meant cutting off the original connectors for the engine mount and speed sender so tape has to do in this case. I may use some split corrugated sleeve on the next swaps.
On to the gearbox oil cooler lines. The originals (of which I have a reference set) are no longer available so I cut the autobox cooler lines apart after the engine mount
I couldn't get the phone to focus to get a decent pic, but I welded a couple of little pips on the end of each pipe to function as a barb to stop the hoses pushing off. There's no pressure in these, but best to be safe. You can just see the bumps in the hoses. I'll crimp these in place once I'm happy with lengths and routing.
Mounted on the engine. They cross under the bellhousing...
...and attach to the gearbox here
I'll need to work out some brackets to support the hoses since the originals are hard lines after the engine mount. I'll be able to produce these in advance for the next conversions using spare autobox lines.
ID:	19806   Click image for larger version
ID:	19807   Click image for larger version
ID:	19808   Click image for larger version
ID:	19809   Click image for larger version
ID:	19810   Click image for larger version
ID:	19811   Click image for larger version
ID:	19812   Click image for larger version
ID:	19813   Click image for larger version
ID:	19814   Click image for larger version
ID:	19816   Click image for larger version
Old 20th July 2018, 10:08 AM
27litres's Avatar
27litres 27litres is offline
I've been waiting for this!
Was expecting the Grey FE to be the prototype though - that will have to be the 'pre-production' model!
What are you doing about the gearbox mounts for the production models? The ones you're using for Bert's look like those "last ones" you got from Audi...
Lastly, when are you coming to Australia with one of those kits in your carry-on?
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 20th July 2018, 10:58 AM
I started off prototyping on the Avus FE, but then Bert's gearbox went pop and he didn't want to spend £3K having it rebuilt only to take it out again once I figured out the swap so we agreed to prototype on his instead. Unfortunately it has taken considerably longer than we expected but hopefully it'll be worth the wait.
Bert's is using the genuine gearbox mounts for simplicity, although I did have to modify the left hand one to clear the shifter. They are pretty simple to copy though so I will redesign them using laser-cut flat plate and make an assembly jig for the pieces so they can be tig welded together. Its likely that's going to come out considerably cheaper than the genuine ones in the end anyway, just like all of the other custom parts.
Not sure I'd get away with a propshaft in a ski-bag on a trip to Australia I'm sure we can figure something out if you want a conversion though
Old 20th July 2018, 07:46 PM
Hi MJ nice to see you've started shouldn't take you long now! i expect you be 99% finished before the end of the month. keep up the good work
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
