Old 16th August 2018, 09:24 PM
Simonbartlett Simonbartlett is offline
Default 3.2fsi advise needed
I'm looking for an a5 convertible for her indoors and have seen a lovely 2009 s line with the 3.2 petrol engine which I assume is fsi. I dont know alot about the engine but it was lovely and smooth. I personally prefered it to the 2.0 tfsi but wondered if it was a bad choice. Are they reliable or any reason I should avoid it ?
Owner of a 2008 A8 3.0tdi SE
Old 18th August 2018, 08:25 PM
Please help b4 i make a bad choice 😀
Old 18th August 2018, 08:37 PM
Sorry - I've never had a 3.2 FSI, but I do know that the 2.0TFSI is really tune-able - so you could easily get the same power out of the 4 pot engine, with less weight.
Probably worth a read of the A5OC forum, and maybe a post on a TT/A3 forum as I think they got both engines also?
Old 18th August 2018, 09:05 PM
Thanks i have been looking but can't find alot of info on the 3.2. Will try again
Old 19th August 2018, 02:44 AM
sarg sarg is offline
Don’t know about the the 3.2, but the 2.0 TFSI has well documented issues and will never sound as sweet nor drive as smooth as a V6 petrol.
Easy choice between those two IMO
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 19th August 2018, 06:28 AM
Am i correct in thinking the tt 3.2 was the vr6 engine which is different from the a5 3.2 fsi ?
Old 19th August 2018, 09:23 PM
A friend of mine has a A5 3.2 on a 09 plate, it’s lovely, sounds great and has never given him any problems.
Old 20th August 2018, 05:47 AM
Thanks thats encouraging. 😀
Old 21st August 2018, 02:29 AM
roberto's Avatar
roberto roberto is offline
Default sorry just saying
a neighbor across from had one
it was nothing but trouble
always had the bonnet up
he asked me to drive it once to see if i knew what was wrong
miss-firing it was
absolutely drank fuel
no thankyou...
here you go bet you could haggle this for £10,000
and its the better engine the A8 never got
http://www.autotrader.co.uk/classifi...01808169538818
Old 21st August 2018, 04:07 PM
miss-firing it was
no thankyou...
Not such good news as I've now purchased it ( I bloody hope your not right ). We have done a few miles today and it drives lovely very pleased with the way it goes and sounds. Nearly as smooth as the 8 !
Once I tried to start it and the starter motor seemed to spin but didnt turn the engine. Tried again and it was fine. Hopefully the solenoid is sticky as it hasn't been used much in the last few years.
