Old 24th August 2018, 08:18 AM
Conquistador's Avatar
Not in Sport mode are you? the throttle response in 'S' is very sensitive from a standstill as I'm sure you know.
If it's not smooth throttle response then perhaps try resetting the throttle position? It would have 'learned' your driving style over time but can be reset. Ignition 'on' but don't fire the car up. Now slowly press the accelerator pedal all the way down ensuring it lasts for more than 5 seconds. Hold it at the full down position for 5 seconds then slowly release the pedal ensuring it lasts for more than 5 seconds. Fire the car up, and the throttle parameters will be reset. Only works for VAG drive-by-wire throttles and you can sometimes here the throttle bodies under the bonnet reset
Doesn't sound like a symptom of the carbon build-up to me.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 24th August 2018, 10:49 AM
homer simpson's Avatar
Nope, I very rarely put it into sport as there is plenty of power on tap
I will try the reset, thank you. It may still be learning my driving style compared to the previous owner. I would be relieved if it isn't a carbon or flap issue. Car has only done 93k and so I would hope it isn't badly coked up yet.
Old 24th August 2018, 11:49 AM
You say that but it's recommended it's done from 80,000mls. I wasn't too bothered until I got mine done at 120,000mls and the place doing it said it was one of the worst they had seen. It felt like the car was brand new after having it all done. Power delivery and response was so much sharper, it's faster and the intake sound is great.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 24th August 2018, 03:39 PM
Definitely on top of the list then! Was yours done at AMD Essex?
I am in the Midlands so have contacted VRS in Northampton which is where 1781cc had his done, just waiting for a reply
Old 24th August 2018, 05:57 PM
Norretal's Avatar
Norretal Norretal is offline
Mine has always done this, prior to flaps deletion and decoke, and now afterwards
I reverse up a slight incline off my drive, if I leave it to tickover until the revs drop below 1000, I blip the throttle and move back and it doesn't do it. Drive back immediately with the revs still up (and without touching the throttle) it does do it. For that reason I've always assumed it's due to over fuelling at that point, though I'm just guessing.
The majority of the time (i.e when I have time) I prefer to leave it to warm through a few minutes before making a move. It's good to hear I'm not the only one who experiences it though
Audi TT - 2015 - Ultra
Old 24th August 2018, 06:28 PM
I'm glad I'm not the only one either!
I'll still try the throttle reset and get the decoke done at some point
