Old 12th September 2018, 01:19 PM
Thanks MJ.
Is it an easy DIY job to remove and replace it, or should I trundle down to my local Audi indy?
Old 12th September 2018, 01:36 PM
Its easy if you have the front end off. I would say the minimum dismantleage is undertray & bumper off and driver's side headlight out. You may need the front end in service position to get to the bracket bolts though.
Old 12th September 2018, 02:00 PM
Yep, a trip to my local Audi indy is due then. Thanks again. Wish we lived in the south-west!
Old 12th September 2018, 03:49 PM
Regulus Regulus is offline
Here is a couple of photos to give you a better view, when the front is off
ID:	20076   Click image for larger version
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 13th September 2018, 11:05 PM
Confirm MJ's part no (as if I would ever dare argue)
got my cam belt changed recently and this was gubbed on mine too, approx £60 from our sponsors, my tame mechanic fitted it in about 10 mins, and didnt charge me either, said it was included in the already hefty bill for the cam belt etc change
Old 14th September 2018, 09:35 AM
Was that a new one from A8 Parts, Brian?
Old 14th September 2018, 09:39 AM
No, was a used one, think a new one was around £87
Old 14th September 2018, 09:47 AM
I was planning to get mine done when the cam belt needed to be changed. But I only had it done 40K miles ago (January 2015) and, IIRC, the interval is 80K or 6 (?) years. I’d also planned to get the tensioners done (after MJ’s warning at the annual meet), but now I’m thinking I ought to bring this all forward.
Any thoughts guys?
