Old 20th September 2018, 12:12 PM
This might help along with the 8 fitting guide
File Type: pdf Webasto_Heater_Thermo_Top_C_Workshop_Manual_(2).pdf (7.80 MB, 3638 views)
Old 2nd October 2018, 07:49 PM
roberto's Avatar
roberto roberto is offline
my A8 has one of these fitted
are they standard
and what does it do and when ?
Old 4th October 2018, 01:50 PM
are they standard
I thought you ordered your car from new? If you've never run it it prolly won't work now anyway. These type heat your coolant to around 60 degs so it's all warm before you start the engine. I think you should of had an extra key fob type thing that controlled it.
Also possible to get a timer unit from Webasto and a 7 day programmable type too i think
Old 4th October 2018, 02:59 PM
jza8's Avatar
jza8 jza8 is offline
IIRC most if not all D3 tdi's had an auxilary heater - meaning it runs together with engine to aid warming the coolant quicker - you can convert to parking heater by adding receiver and remote control + some coding required probably.
2010 Audi A8 4.2 TDI
Old 4th October 2018, 08:22 PM
And a pump
Old 5th October 2018, 04:33 PM
roberto's Avatar
oh...
next time i start her up i will check the tiny exhaust underneath see if i feel any heat..
mind you that might be december time as it sorn for the winter on trickle..
