IIRC aux heater only becomes active when ambient temp gets down to 6 degrees or around that .
If you feel that it is taking to long to get warm ,like already said it could be a thermostat issue ...opening to soon or not fully closing allowing partial flow through the radiator. As a bit of a ‘bog ‘ just for *testing purposes* if you slip some cardboard in front of the radiator ( like ya used to see in’th olden days ...Ray will know ! ) just to stop air flow to it ....if it then gets warm much quicker you know your on the correct track . There is a few other things that can cause slow warm up ....any ideas technical guys ?? Just out of interest so |
Cheers mate
2006 Audi A8 4.2tdi Sport |
Chhe
Cheeky booger Lee. I'm not doing anything today so I might bring the boys round to have a word I used to be in charge of the honorable ancient blowlamp for warming up Boadicea's chariot wheel knives. It made the blood flow easier after cutting.
https://audi.7zap.com/en/rdw/audi+a8.../1/121-121039/
Part 6 on this diagram is a common failure that results in cool running/slow warmup due to bypassing the main thermostat and continually circulating the radiator and autobox cooler. They are about £15 new on ebay. |
I have been reading on that fix - do you have any info on replacement of this part?
Thanks for your help.
