IT, AV and other Tech All computing, home cinema and technology that isnt car related |
#951
This looks interesting ...
https://bitcoinmagazine.com/articles...ning-firmware/ https://braiins-os.org/
#952
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
#953
Haven't found any or tested it myself yet but there's a discussion thread on BCT here:
https://bitcointalk.org/index.php?topic=5036844.0 One poster seems to suggest they're using it to overclock to 15TH but at the price of greater power consumption. There's mention of 'AsicBoost' too, although someone just posted a link to this Bitmain announcement in the thread today: https://blog.bitmain.com/en/new-firm...ation-firmware
#954
I have tried Dollemizer which offers overclocking and voltage setting but only all hashboards at the time, not individually. My autotune S9 13.5TH is automaticallyselecting 870, 880 and 890mV for hashing boards. With Dollemizer I could not reduce voltage below 890mV without loosing hashrate. At 890mV I could overclock it above 14TH but power usage was going up considerably as well so I was not even trying to see how high can it go. There is also devFee for Dollemizer 4 min mining for developer then 200 min for you and then repeats again. So I switched back to stock firmware.
#955
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 23rd October 2018 at 05:18 AM. |
#956
I'm selling my Vega rig if anyone is interested:
2x Gigabyte and 1x Sapphire Vega 56s all running the Gigabyte 56 bios Asrock H110+ mining motherboard Intel low-power CPU Ram M3 sata drive 800W psu Mining rig frame Since the Monero algo change to Cryptonight v8 its using 600W for 5.4MH/s which covers its electricity costs on Nicehash at 13p a unit. Since v8 has introduced some instability compared to v7, I might as well just run the central heating instead. I'm sure the various developers will sort the instability out in due course, but I'm done babysitting it. The two Gigabyte cards have been fed cold air from the loft. The Sapphire was just running on ambient. They all run happily at ~65 degrees with auto fan control on. Its running Windows 10 Pro 1607 with updates disabled. I'd like to see £1200 for it. |
#957
#958
I'm getting tempted to turn on the S9. The office could use some heating and I could replace my older S7 with it and get back in the game - I've held all i made, but power costs and hardware costs probably put me quite down as things go!
#959
#960
The cats were cold so I made this to restart Cast-XMR every hour which will catch and reset an unresponsive GPU and avoid dead time.
Code:
$application1 = "C:\mining\cast_xmr-vega\switch-radeon-gpu.exe" $params1 = "--hbcc=off autorestart" $application2 = "C:\mining\cast_xmr-vega\cast_xmr-vega" $params2 = " -S cryptonightv8.eu.nicehash.com:3367 -u username -G 0,1,2 -O 1 --nicehash -I 7 -R --remoteport 7777 --fastjobswitch --algo=10 --forcecompute --ratewatchdog" $sleepTime = 3600 $i = 1 while ($i = 1){ Write-Host "Starting mining" Start-Process $application1 $params1 -PassThru $process = Start-Process $application2 $params2 -PassThru Write-Host "Waiting " $sleepTime "seconds" Start-Sleep -Seconds $sleepTime if(!$process.HasExited){ Write-Host "Killing mining" $process.Kill() } else{ echo "Mining had already ended" } Start-Sleep -Seconds 2 } The rig is still for sale, but it might as well keep the cats warm until then ![]() Last edited by MikkiJayne; 25th October 2018 at 01:35 PM. |
