Old 25th October 2018, 10:47 AM
Dakes55 Dakes55 is offline
Default Rear Screen Heater Module Location
Does anyone know where the rear screen demister control module is located on a 2002 2.8 FL quattro, the manual states that its behind the right hand side panel in the boot, but on mine its not, I have taken off both side panel covers and plastic covers on both sides of the boot, and on the left side there is only the central locking pump and alarm module, on the right hand side there is nothing there, any ideas where else to look?
Thanks
Old 25th October 2018, 10:56 AM
Sure you're not getting confused with the front heated screen control; I think that is back there (oddly).
Old 25th October 2018, 10:58 AM
It's the front screen heating module in the right side of boot. Rear screen is operated by climate control unit of FL and a simple switch of PF.
Old 25th October 2018, 11:07 AM
My car does not have a heated front screen, I have checked behind both sides in the boot and there is nothing on the right side, and on the left side there is only the central locking pump and the alarm module, I can hear a relay clicking in and the light comes on when the demister button is pressed and it goes through it timing cycle, turns itself off after a while as it should, but it seems like there is no power getting to the rear screen as its not clearing it, I have all the manuals and they state the demister control module should be located behind the right hand side panel, but I checked and there is nothing there, its a bit weird this one.
Old 25th October 2018, 11:34 AM
All of which is consistent with what has been said to you above.
What year and exact model is your car, as noted above REAR demist controls changed slightly at the facelift?
Old 25th October 2018, 11:40 AM
The car is a 2002 D2 FL Quattro, 2.8 long wheel base
Old 25th October 2018, 12:33 PM
You cannot find it because there is no such thing. It's just 30A fuse, wire to HVAC unit, switch/relay inside unit and wire to the window.
Old 25th October 2018, 12:51 PM
Great, thanks for the info, I thought the wiring diagram looked very simple, ill check the fuse again, but last time I checked it was ok, thanks again
Old 22nd November 2018, 05:56 PM
I have looked at the wiring diagram for my car and it does show that is just a straight wire to the rear heated rear window, protected by a 30 fuse, for some reason there is no power getting to the rear screen heater, the fuse is ok and the relay is working ok, so im thinking it must be a break in the wiring somewhere
Old 23rd November 2018, 10:27 AM
FYI, Long Wheel base was 4.2 only in the UK......
If its a UK car, and it has the V6, its a SWB
