Old 15th December 2018, 07:08 AM
hunker7 hunker7 is offline
Default 2000 D2 drivers front suspension strut
Hi guys, as per title I'm after drivers front suspension strut as some genius didn't tighten balljoint properly so it's all broken and can't be tightened.
Old 15th December 2018, 07:16 AM
Damn. Is yours an S8 or A8? What's the VIN?
Old 15th December 2018, 07:33 AM
A8 2.8. I'll get VIN as soon as I can.
Old 15th December 2018, 07:43 AM
If its after 4D-X-005 501 (should be if its a 2000) then you need the alloy non-brembo hub which is sadly becoming very rare.
Our sponsors haven't got any (otherwise I would have them) so you'll need to keep an eye out on ebay etc for someone breaking one. Any A8 2.8, 3.7 or 4.2 will do from late 99 to 01 - check with the seller first that it has alloy hubs. Cars with 20" wheels have steel hubs which are not interchangeable, as do X-500 000 to X-500 500. I would suggest you buy both sides if you can find them so you have a spare the other side.
Old 15th December 2018, 09:01 AM
Sent you a PM mate.
