Old 22nd September 2010, 07:58 PM
Will it stop if you brake hard? Does it stop below 40? Does it happen from cold or only when you have braked a few times and warmed them up? I would suspect a sticking calliper or dirty ABS sensor. Probably dirty ABS sensor that is actuating at that speed. Get both the front sensors out, give them a good clean and see if that cures it.
