I would imagine it gives out DC, otherwise you'd need an enormous rectifier/regulator in the car to be able to handle that kind of power. It would make more sense to rectify and regulate the voltage at the charging station rather than burden each vehicle with the bulk and weight of the extra circuitry.
![]() Then someone will look at that and say, hey we know how to build small efficient diesel engines cheaply so why not cut out the heavy expensive batteries and just put diesel in every vehicle.....
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 20th February 2019 at 09:42 AM. |
It depends by vehicle - the Zoe I had was AC charging. It's an AC motor anyway, so all they are doing is reversing the direction through the conversion system
Even if the vehicle receives an AC charging feed, there will have to be rectification and voltage regulation for charging. For slow-charging vehicles it's practical to have that circuitry on-board. But, if you're fast-charging at hundreds of amps, you're gonna need some pretty big rectifier diodes!
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 20th February 2019 at 10:20 AM. |
Yeah exactly ^ The articles I've seen say that slow chargers tend to feed AC in to the vehicle's on-board charger up to about 20KW, but those 100+KW fast chargers feed DC direct in to the battery and have the power electronics in the charging station.
800V @ 500A DC ![]() |
That is a staggering amount of power! In fact I'm amazed they can fit the circuitry that can handle that into the charging station.
To put it into perspective, the closest PSU I can find is 800V @ 400A, available courtesy of the Suzhou Lingfran Electric Co., Ltd: https://www.alibaba.com/product-deta...445757754.html ![]() Should just about fit in a Tesla boot I reckon! ![]()
I'm amazed they can fit a consumer-safe connector of that scale in to a car.
Apparently the connector and the cable are liquid cooled, and the proof of concept 400KW charger's cooling system could heard over the neighbouring truckstop! |
Yeah, that's certainly some achievement to produce a connector capable of handling that amount of power safely!
Especially when you consider the average domestic mains plug/socket tends to char and burn if you run it at the full rated power for more than about 10 minutes .... And that's just 240v @ 13 Amps! ![]()
#30
Like everything else in the pipedream realm
Nobody understands the power/weight ratio. DC at that power needs a rather fat cable. Car starter is 12 volts @ 100Amps and look at the size of the battery to starter cable. Think of the heat that would be generated if a connection became slightly loose. Then the connectors being used by Joe Public. Hopefully not in my time.
