Old 28th February 2019, 02:38 PM
Thanks! I'm so happy to have the window working again.
Its really easy, just unbolt the three silvery 6-star bolts, unplug, then yank it out. The motor unit engages the window pulleys via a big plastic pinion gear. I didn't swap the motor on its own, I swapped the whole black-cased mechanism that the motor is attached to. On closer inspection my old motor had leaked some kind of oil all over its casing so it was toast.
The motor itself has 4 smaller bolts that attach it to the mechanism but one of them is not accessible without removing the whole unit first.
Good luck hope it goes well.
