Old 31st March 2019, 12:52 PM
Great to see how you are turning back the clock (metaphorically) on Jim's car MJ. Excellent tread.
Jim, I bet you're looking forward to getting back into it again. I know I would be.
Old 31st March 2019, 03:17 PM
Mark, I just checked if they fit anything else and they are also used in the D3 so we should have supply for another 5 years in theory.
Old 31st March 2019, 03:34 PM
Great That's good to know.
Old 31st March 2019, 06:16 PM
After my bad experiences of the local Audi indy people in my (relatively) new neck of the woods, it is wonderfully reassuring to have my car in MJ’s capable hands. Well worth the 4 hour drive and a couple of weeks or so without a car. And reading a ‘what’s in the workshop’ write up on your own car is brillaintly exciting!
MJ made me very welcome and we did a reccy with the car on the lift, so there are a couple of other jobs to be done as a result. And I’ll be back at a later date for a rear subframe rebuild.
And as an added bonus, I had a short trip in MJ’s car when she gave me a lift to a services to meet up with a friend for a lift home. Even from the passenger seat, you can tell how ‘tight’ MJ’s car is - it’s like a brand new car (which it pretty much is!). And the interior is a beautiful place to be - the red leather and black trim is a very pleasing combination.
I can’t wait for the next post - thanks MJ!
Old 31st March 2019, 08:30 PM
This morning's activities:
ID:	21047   Click image for larger version
Old 31st March 2019, 09:12 PM
This afternoon was spent removing engine parts and prepping it for cleaning
I think this is where most of the gunge on the lower half of the engine came from
Attached to the bracket for the engine stand
On the stand
Locking tools in
Started taking the timing gear off. This is a new one This is the tensioner roller and you can just see that there is a threaded insert stuck on the bolt. The threaded insert should have stayed in the engine but it appears the thread of the bolt is a bit mashed so it took the insert out with it. This is going to be 'interesting' to repair...
Whoever gorrilla'd the tensioner bolt apparently attacked the cam sprockets with a lump hammer too
Drained the remaining coolant from the block. Its a good sign that both drains are clear. Oil cooler drain first
passenger side drain - this drain is almost always blocked, but on this engine it runs free
The vac hoses are completely perished so I'll replace those
I left the oil draining overnight, ready for tomorrow
ID:	21059   Click image for larger version
ID:	21060   Click image for larger version
ID:	21061   Click image for larger version
ID:	21062   Click image for larger version
ID:	21063   Click image for larger version
ID:	21064   Click image for larger version
ID:	21065   Click image for larger version
ID:	21066   Click image for larger version
ID:	21067   Click image for larger version
ID:	21069   Click image for larger version
ID:	21070   Click image for larger version
Old 1st April 2019, 08:40 PM
4 hours of cleaning...
I pulled the oil cooler housing off. The plastic pipe had already cracked. That's getting replaced with an aluminium one.
Yeuch
I really don't know why these engines collect sand between the inlet manifold and the head. They all have it, and one has to be extremely careful when taking the manifold off to not get any down the inlet ports
Flange cleaned up and the inlet ports protected
There was evidence of coolant leakage down the back of the block so I pulled the water pipes off the back of the heads. Just as well I did since one o-ring had turned to fluff and the other was already leaking.
Cleaned up the valley
Breather cover removed - the gasket on this is the source of all the gunge in the valley and also all the oil down the back of the block. There's a little drain hole on the left of the pic where everything that leaks from here escapes down in to the bellhousing
More grub
2 gallons of degreaser later...
ID:	21078   Click image for larger version
ID:	21079   Click image for larger version
ID:	21080   Click image for larger version
ID:	21081   Click image for larger version
ID:	21082   Click image for larger version
ID:	21083   Click image for larger version
ID:	21084   Click image for larger version
ID:	21085   Click image for larger version
ID:	21086   Click image for larger version
ID:	21088   Click image for larger version
ID:	21089   Click image for larger version
ID:	21090   Click image for larger version
ID:	21091   Click image for larger version
ID:	21092   Click image for larger version
Old 6th April 2019, 04:04 PM
Also I believe nylon pads get brittle with age in a hot engine oil environment. There are newer type nylons such as Stanyl 46 or Stanyl Diablo which last longer before getting brittle in engine oil. I asked a couple of companies how much it would cost to make a copy of our pads in one of these newer nylons but their minimum order is something like 10,000 units
Another option could be to have replica pads machined out of a block of one of these new nylons, but machining costs are not cheap either.
If there is a way to repair old tensioner units that would be amazing. Over £1000 for a pair of new units is a bit much.
