Mine sinks right to the bottom, there is zero suspension on my right front. You can feel everything if you try and drive it, it's not pleasant.
Rear is perfectly fine, and holds air with no problem. Hopefully I'll get around to fixing it sooner or later, I did move her slowly (in jack mode) to another part of the farm so I could clean her yesterday. First time it's moved in a while and apart from the front all is well. ignore the off height of the rear suspension, the car was moved in jack mode and the ground is not level where this is taken. The level is fine outside my house.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 7th April 2019 at 01:02 PM. |
Attachment 21249
Hi Mannyo, does yours go as low as the attached photo with the tyre hidden up the wheelarch? Attachment 21250 Attachment 21251 I checked the top where the cable comes out with bubble mixture, nothing, also the air inlet area and the lower few inches of strut housing where there are some seals, no leaks. I have ordered a used valve block and will fit this. I don't have time to test much more, also driving to Keukenhoff in Netherlands in a less than a week so really hoping this works or will struggle. Last edited by snapdragon; 23rd April 2020 at 08:18 AM. |
If that doeesnt work (and I hope it does) then I still maintain that a low output on the air suspension compressor (anything under 10-12 bar) will not be able to keep the system topped up properly and you will be getting lots of "high temperature cut outs" of the air compressor as it tries to cope. There is a thread somewhere on here from Delboy which explains how to add some additional functionality to VagCom so that you can see the output of the compressor and also individually (or per axle) raise and lower the front and back air jacks.
I had repeated issues and replaced a couple of air jacks but as soon as a replacement compressor was fitted all of the rest disappeared until nearly 2 years later when a third air jack leaked and so I also replaced that one. *EDIT* Delboys Thread is here - http://forum.a8parts.co.uk/showthrea...437#post102437
Confidence is the feeling you have before you know better . . . . ![]() Audi A8 D2 3.7 Quattro Sport 1999 FL - Melange 2nd Place Winner - A8-Freunde Annual German Meet 2012 at Edersee 20" x 9" Bentley GTC Wheels with 385mm W12 Front Discs & Bentley Caliper Covers, Front Lowered on Coilovers, Xenons, Combined DRLs and LED Foglights to modified OEM front fog lamp position, Alcantara/Leather, Full Black Alcantara headlining + pillars and blind shelf, Bespoke Flat Bottomed Sports Steering Wheel, Dark Myrtle Wood, Autodim Mirrors, Bose, Blinds, Digital TV, Ski Hatch, Modified rear exhaust section for extra V8 Burble ![]() Audi S8 D2 Final Edition 2002, Avus Silver with Red Leather Interior Tiptronic with Sport mode button, Sony rear entertainment package, Bose sound system, Audi Navigation Plus, 20 inch Final Edition alloys, Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() Audi A8L D2 4.2 Petrol with LPG - Ebony Black Audi A8L D4 FL 4.0T Petrol twin turbo - Havana Black Audi A2 1.6 FSi Sport - Dolphin Grey with Votex body kit and Red Leather Interior and some other A8's A8L's and Mercs Last edited by Architex_mA8tey; 8th April 2019 at 01:42 PM. |
Well, mine is still not repaired.
However, I did move and wash it a couple of weeks ago. Rear of the car sits at a good height and front is on the deck. I now have a replacement strut, I opted for a refurbed one rather than going second hand. It was shipped from Germany, it looks good however I have not yet had it fitted so cannot vouch for quality. Not sure I am going to attempt to fit it myself yet, I did look at the bolts and I am not sure the control arm bolt will come out easily, along the lower one. The big problem is that if the bolts shear off or will not undo then I do not have the facilities to deal with that and I could be left with an even more stranded car. I need to try and save some money again, I only have a temp low paid job until mid July, so may have to sell the car as is with the replacement part. MOT is due at the end of July and its hardly been used since the last one, she needs a cambelt and oil change, I simply have no spare money at all to spend on the old girl and the lack of use I am sure is doing it no good at all.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 24th April 2019 at 07:43 PM. |
My new valve block didn't help, so I will be getting an airspring assembly and remove the strut and take apart and fit this. It will be a struggle I know. Sadly I missed a used strut off a 2009 for a reasonable price. The rest of the used ones are tired, old and very expensive for such old and battered parts. I fear the Chinese new ones may be inferior, I read a couple of reviews that said the adjustable damping is bogus/inoperable on them. That leaves refurbs but these seem quite above my price range at the moment.
I've moved the cars around today. This is how the Audi sits today with the front low down, there is no suspension movement on the front.
Compare this picture with the one in my signature where the car is in dynamic (taken many years ago now). Look at how the alloys have corroded for example. I may remove the wheel tomorrow (weather permitting) and check out the bolts.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 27th April 2019 at 09:59 AM. |
Took the wheel off today to have a look at how it would be to change. After cleaning things up they do not look too bad, but I do not have sockets or spanners big enough.
Pictures below are of what I am dealing with. Not sure if the strut is original or not based on part number.
