Old 3rd May 2019, 01:39 PM
Yeah that's the one Still available from Audi last time I checked. Mike and I have laser-cut alloy plates for mounting the Spal fan now too if you want one.
Old 3rd May 2019, 06:05 PM
Thanks Mikki, yes please can I have a laser cut aluminium shroud? How much are they?
Damn those pulleys aren't cheap.
Should I get a new bolt for the pulley or reuse the old one?
Old 3rd May 2019, 06:53 PM
£65 odd aren't they? Or have they gone up? I believe the pulley comes complete with the bearing so you shouldn't need to change the bolt.
I'll check with Mike what the mounting plate costs as we need to get a few cut
Old 4th May 2019, 03:29 PM
I saw some prices in $ around 160 which got me worried it will be similar in £. £65 wouldn't be so bad. Should I try the dealer or TPS?
By the way I saw you mentioned the new fan on speed 1 is not quite enough for aircon, did you try both fans on speed 1, what was the amp draw?
I may leave the stock fan on speed 1 and add the new one in parallel.
Old 20th May 2019, 02:56 PM
I may have solved my overheating problem, went to locate the twin thermostat in the radiator to find some numpty left it unplugged!
At least it should be a free fix, hopefully its still working.
I am still going to try the electric fan conversion.
Old 20th May 2019, 03:23 PM
D'oh!
We've ordered more fan surround panels btw. I'll let you know when they land
The new fan is too many amps to run in parallel with the original btw, although you could wire in a separate supply for it. Mine works nicely with it on speed 2 though. When its idling the second fan cuts in and out as needed, with the original running constantly at speed 1.
Old 20th May 2019, 08:15 PM
Thanks
Did you change the setup from your original post where you had the new fan replace the old one on speed 1? And the old one still comes on speeds 2 and 3?
