The plastic pipe won't fail catastrophically because it is constrained by the oil cooler housing.
It is possible to change it with the engine in if you are determined enough. Its just not a pleasant job because of limited access, although its much easier with the front end off. I'll change it as a matter of course on an engine-out service, but I wouldn't take the engine out if that was the only job. |
