Old 13th May 2019, 09:06 PM
jonnypym123 jonnypym123 is offline
Yeah I think your right either not mapped or poorly mapped, I'll get to the bottom of it and report back on here, I'm just going off my previous experience with a 2006 D3 3.0tdi pre and post map, my gut feeling is they realised they had to faff on with 2 ecus and told me anything, the performance is definitely stock to what would be manufacturers spec 0-60, I would have thought remapped would be low 5s 0-60, I want that chewing tyres feeling at the rears
Old 17th May 2019, 06:09 PM
Here's the last flash date looks to be 2years from new so I'm
doubting its remapped what you reckon
Friday,17,May,2019,19:01:51:46565
VCDS Version: Release 18.2.1
Address 01: Engine
Control Module Part Number: 4E1 910 409 A
Component and/or Version: 4.2L V8TDI G000AGMª0070
Software Coding: 0011773
Work Shop Code: WSC 00641
VCID: 224A62A1FD7A145411-8076
Advanced Identification
Serial number: AUX3Z0E9377249
Identification: BPG-810
Revision: --H01---
Date: 12.10.05
Test stand number: 1883
Manufacturer number: 0045
Flash Status
Programming Attempts: 1
Successful Attempts: 1
Programming Status: 00000000
Required Conditions: 00000001
Flash Tool Code: 146001 210 00641
Flash Date: 09.04.08
Software
A 4.6.5
Misc.
Hardware number: 4E1 907 409
Immo Challenge: A6 87 5C DD
Car Info
Chassis Number: WAUZZZ4E66N014310
VCDS Info:
Labels: Redir Fail!
Readiness: No script available
Old 21st May 2019, 11:48 AM
I've took some MAF and torque logs via VCDS can anyone take a look and work out if it's been remapped?
Would really appreciate any help
peak torque logged from VDS was 799.9nm I know this is what the engine thinks is outputting but it appears to be high so I'm thinking it might be remapped what do you reckon?
ID:	21645   Click image for larger version
Old 15th August 2019, 06:36 PM
Made some progress on trying to determine id my D3 4.2tdi has been remapped, 6
Did a VCDS Acceleration 0-60 test tonight, quite a good feature. From the results it looks pretty stock to me 0 to 60 mph: 6.2 +- 0.36swhich meant the company BTG I had took it to and said it had already been remapped must have been trying to get out of a cheap remap.
Question is does anyone know what a D3 4.2tdi 0-60 which has been remapped would be roughly?
Thursday,15,August,2019,19:09:34:46565
Control Module Part Number: 4E1 910 409 A Component and/or Version: 4.2L V8TDI G000AGMª0070
US Units
