Old 27th May 2019, 11:41 AM
irelandbuyer irelandbuyer is offline
Diamond cut is only worth the extra expense if the car doesn't get heavy use (e.g. as a daily driver), as the surface finish is almost impossible to protect fully, no matter what the provider says or what finish they/you use to protect it.
PS: even if you DC, it won't give you a "true" OEM finish, as the inside face of the 20" OEM wheels are finished differently, and completely impossible to replicate.
Thanks Tintin...
My problem is exactly that. It is a daily driver, albeit i only do about 3k miles a year. Not sure about you, but i seem to always scuff the rear passenger side and clip corners etc....you would think i'd be used to the size of the car at this stage!!!
2007 Audi A8 D3 3.2 FSI
