Old 15th July 2019, 08:42 PM
I thought 3G MMI came in with the 2nd facelift with the later tail lights, ectangular front fogs and indicators in the mirrors - is this not always the case?
Nope, not the case....
Look at Ollies 57 plate car he just sold for a great example.... Facelift with all those features you mention, but 2G.
3G was a very separate, and quite subtle upgrade late on in the D3 lifespan....
Old 5th January 2020, 02:48 PM
dangerdred dangerdred is offline
Sorry for the dated thread, but I ended up looking at this to try and find out how I get the digital speedo displayed between the clocks and after reading, I'm still at a loss as my car is 2008 FL and my clocks are I'm presuming wide - 4E0 920 951 J, but I do not see an option for enabling digital speedo anywhere. Please can anyone advise.
Phantom Black 2008 A8 3.0 TDI SE ASB
Old 5th January 2020, 03:22 PM
homer simpson's Avatar
On the wiper stalk, there is a button on the under side. Pressing it toggles through the various displays, one will be digital speedo.
Old 6th January 2020, 03:45 PM
Thanks for that. I must have pressed this before and when I saw it didn't seem to do anything I never went back to it - two presses brings up the digital speedo. Is there meant to be some function to the first press?
Old 6th January 2020, 04:59 PM
If you've got an adaptive cruise widescreen cluster then you wont get the digital speedo as well as apparently it needs to be able to use a "vacant" screen display option to show the distance between vehicles you've selected and the digital speedo was the one they chose to replace.
I know this because I've already replaced my cluster with an adaptive cruise one and had the same question as to why it had disappeared!
I have a facelift with adaptive cruise and I have both screens. Perhaps a coding issue?
The first two look the same but do show different readings at the bottom. I think they are average MPG and live MPG but I culd be wrong without checking.
Old 7th January 2020, 08:14 AM
I have a face-lift with adaptive cruise and I have both screens. Perhaps a coding issue?
My car is an early face-lift model - is yours the later facelift model?
It may possibly be because until I have fitted the adaptive cruise widescreen dash but had to currently still code it as the standard widescreen dash to ensure the standard cruise control still works until the rest of the adaptive cruise kit (which I now have) is fitted
Old 7th January 2020, 10:58 AM
Mine is a 2008 so yes one of the later face-lifts.
Old 27th January 2020, 04:04 PM
Yes, not sure how I missed it before now that it seems so obvious, but first two screens display Tripmeter 1 and 2.
Old 6th January 2020, 02:29 PM
