Old 28th July 2019, 04:57 PM
Could also be the lambda sensors reading lean so the ecu is over-fuelling. Try unplugging them as a diagnostic step as the ECU will just run open-loop using the MAF. If it improves the reading then replace the sensors. If not, look elsewhere
Old 28th July 2019, 06:38 PM
jt racing jt racing is offline
Great thats a start... Will try that 1st....
Thank you.
Old 8th August 2019, 08:00 PM
Just following up here. Have replaced left bank o2 sensor as it seemed dead according to the diagnostic in the garage and after a smoke test 2 breather pipes from the inlet manifold were split open.
After that the emmisions in the garage recorded fine, so nct retest Tuesday... Fingers crossed.
Old 14th August 2019, 07:35 PM
Passed retest... Was the above. Whoop whoop!
