I have another unit which is in better nick. The batteries have started to corrode, but the circuit board looks not too bad. But where can I get the batteries? The part number throws up a very similar batter, but with only 3 connections instead of four.
Electrically, there will just be the usual 2 (positive and negative) connections on each battery but some have additional pins for better anchorage. Usually any extra pins are connected by a PCB track so it's possible to make a different pin configuration fit with some coper wire and a bit of fettling. It should be possible to find one with the same configuration though. What's the spec' and part number printed on the battery?
There are two batteries marked as follows:
VARTA 2X3.6V 140 mAh 2x3/V150H Ni-MH 103 —>+
TPS will still sell you a newer one of the correct spec, if needed. The sirens are all pathetic - I activated the chirp just so I knew the poxy thing was doing something for the expenditure! You also need a different nut to fit it as the thread is different 🙄
I had to replace the plug and wiring as the corrosion had eaten the pins and plastic - it did make fitting the new siren easier as the OEM wiring is very short!
I think I would probably just check the dimensions and make my own battery 'pack' instead, using something like this (assuming that has the correct dimensions). You'd need to tape (or, preferably, heatshrink) 2 of those together and solder wires to them instead. Don't solder directly to the battery though; some batteries have been known to explode when exposed to excessive heat from a soldering iron.
Still think you should follow my example
Audi S8 2015, Daytona Grey |
I cut my old one open too when it failed but that was largely out of curiosity. After determining that it wasn't worth repairing, I swiftly binned it and replaced it. Replacements units were readily available at the time though; I might have been more inclined to persist with the repair if they weren't. In any case, I like chirps; it's a helpful confirmation that all the doors are fully closed and locked as you walk away (since it won't chirp if any are left ajar). So I'd still repair or replace if possible.
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 22nd August 2019 at 08:22 AM. |
