Old 30th August 2019, 05:56 PM
Nognar Nognar is offline
I would not wish this job on anyone!
Its in one of the hardest places to get too right at the back of the engine and my god its taken some doing this afternoon. It was not the lower expansion hose in the end as I thought but the pipe next door to it which is a heating hose 4D2819371B.
Gave it a pull and it tore in two parts easily!
You can see from this photo it was not in the best of condition after 17 years of use!
On the bench and now in two parts!
Joy of joys and arms do not look good after that and quite cut up! Right time to order one of those and then the fun of fitting it, I wish I was closer to Devon.
30 second job I suspect if the engine was outside of the car
Old 30th August 2019, 06:10 PM
Ooh not fun at all! Look on the bright side though - still orders of magnitude easier than doing the metal cross pipe
Old 22nd September 2019, 08:44 PM
Hooray!
Its arrived, not that cheap in the end with postage but needed to be done. Now just need to find the time to fit it!
Old 28th September 2019, 04:27 PM
Spent some time with the car today fitting the new coolant pipe and noticed a couple of interesting items when doing it.
The pipes and the fitting in the engine bay did not look quite right and then noticed that as the car has LPG its taken a feed from the cooling system into the LPG pump in the engine bay. Now due to that installation a couple of problems have been caused, the metal T pieces for the tapped feed are 14mm which is fine for the pipes going to the LPG but the D2 coolant pipe has an 18/19 mm internal diameter, so not a good fit.
Hence I have ordered new pipes, clips and T pieces to get the job done to a much higher and hopefully reliable standard.
Finally and what I believe was the root cause of the failed coolant pipe is due to the above LPG installation. The heater hose is the one that failed and that normally connects to the right feed from the heater matrix in the engine bay. As this has LPG an extra pipe and T piece was fitted for the coolant feed, nothing odd in that but due to the way it was installed it pushed the heater hose 2 to 3 inches down into the engine bay and much closer to the exhaust.
Therefore we had a hose closer much closer to the exhaust than it should have been and I suspect failed much earlier than normal due to the increase in heat is was exposed to.
Old 5th October 2019, 03:42 PM
Duffy Duffy is offline
I occasionally see Jim the LPG man, I’ll feedback to him on this at some point
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
Old 5th October 2019, 05:51 PM
All repaired and fixed now, driving beautifully again.
