Go Back   A8 Parts Forum > Our Other Audi Friends > A4/S4 B6
A4/S4 B6 2001-2005
Old 26th September 2019, 09:16 AM
mannyo mannyo is offline
You asked, so here are some to get started.
ID:	22162   Click image for larger version
ID:	22163   Click image for larger version
ID:	22164   Click image for larger version
ID:	22165   Click image for larger version
ID:	22166   Click image for larger version
Manny
Past
Old 10th October 2019, 02:00 PM
1781cc 1781cc is offline
Love this - I did the same nearly 2 years ago when I sold my D3 S8, I have a 2006 A4 B7 3.0TDI Cabriolet.
You should come over and play with us on Facebook in the A4 Cabriolet Club UK: https://www.facebook.com/groups/1799558050155190/
Old 11th October 2019, 12:20 PM
One thing my B6 has which seems pretty rare, and that's the fully electric front seats in Red leather which is down on the original invoice as costing more than £1K
Not sure if they are Recaro, but they both have electric height adjust with independent front/rear of the seat base, Electric back rest, lumbar, electric headrest up/down. Same adjustments that my old D3 had, except the front pull out extension is manual.
I've resolved the radio problem, it was the cable between the boot lid and car body failing. Rejoined it and soldered, then sleeved and the external shielding repaired.
The oil problem is a non issue, it was resolved by the previous owner having spent a significant amount of money replacing failed pipework.
Only issue remaining now are the rear springs. Both have failed in the same place, and lost a piece off one end of the coil. It's sitting a little low on the back as a result as you can see in the pictures. I know it has sport suspension, also as an option.
Manny
Past
