D3 - Common Faults Quick links to all known common faults and their solutions |
I went to check the drain behind the footrest, but its bone dry there, it seems to be dripping from the dash as the bonnet release has water on it, any other ideas?
Mine was the aircon drains!!
Either side of the tunnel up nearly as high as the top as the footrest but back towards the driver by about 9 inches as per pictures for drivers footwell. The other side is reflected on the other side of the transmission tunnel but same position
Thanks for your help guys, going to stick it in the garage and investigate when i have time, if it is the ones you're talking about, is it a case of just emptying the water in there, or did you use some compressed air or something to try and unblock wherever it is blocking from?
Well finally had time today to try and source the issue and sort it.
My headlining was damp,so the culprit was a blocked right sunroof drain, luckily my dad has an air compressor in his garage so i soon had it unblocked, was just a few old manky looking leaves that came out. Luckily water is running freely now and its raining again so time will tell. |
HI All,
Can I urge caution when using garage air compressors to clear out the drains. If they are extremely blocked a big blast of air could blow the drain pipes. It is much better to try to access the end of the drain plug have a look there and see how clogged it is. I bought a hand weed killer pump sprayer (the ones with the srap on them) from I think Aldi or LIdl, took the spray head off which leaves the brass tube. This actually fits perfectly into the drain hole in the sunroof. Pump up some pressure, not too mad and that'll drain it. I use warm/hot water with some mild detergent until i see it is running clear. I just keep it in the garage and i do it every now and then... Good luck with the drain cleaning...i must go and do mine again soon...
2007 Audi A8 D3 3.2 FSI |
