I did it on A6 but on D2 I could not get the bolt turning. I also first over-did it on A6. I did it by feel with the rack near mid position but as the most of the time rack spends near middle position it's more worn in the middle. When it felt fine in middle it was too tight on more lock so had to loosen it a bit.
Thanks for the advice everyone. I can now make it clunk by shaking the steering around the centre point. I think the main cause is cleaning off the grease and replacing it with a much softer grease. I have already checked that everything is tight.
I didn’t know this but grease has a thickness rating 1-6. 1 is semi fluid and 6 come as a brick like fudge. I have ordered some 3 and 4 in case the proper grease is not thick enough to cushion it after adjusting. I expect I have most of the wear on centre and so adjusting will be between two conflicting compromises of binding off centre and backlash on centre. The grease rating is called NLGI. Sometimes the name of the product will have this rating number e.g. EP2 or NG3. The racks are £200-400 remanufactured which is not bad but the task of fitting looks terrible. Maybe this greasing should be a maintenance item say every 100,000 miles to help reduce wear. Last edited by snapdragon; 10th October 2019 at 06:02 AM. |
I had this same issue with the rack in Neil's D2 - very worn around the centre but fine at the edges. If it was adjusted enough to take out the play in the centre it wouldn't move more than a few inches in each direction. Loose enough to get lock to lock and it was scary in a straight line. We enquired about a re-con rack but all they do is replace the seals for the D2, and don't replace the actual rack and pinion so if your return rack is toast you lose your deposit. We just fitted a used one instead.
Thanks everyone, with your help I was able to fix the issue.
I removed the rear wheelarch liner, plastic protector for driveshaft and rubber insulator that the inner tie-rod passes through. Removed the tie-rod assembly again and steered left to send the rack-bar out of the rack. I then cleaned it really well and applied liberally Millers DELTA 3EP as this seemed most like the original (The BMW stuff was very soft yellow grease) Here are the photos but they are all rotated 90˚ CCW (why does this happen on this forum, I have also resaved and reuploaded them with the same result?), you can see the spanner on the nut on the 'movie'. The nut turned easily and in a few increments with test drives, I did it a full turn when the rack was dry and then greased it up once satisfied - there is no binding off-centre, in fact it feels no different than before. One day I will do the plain bar on the passenger side just to protect it. Attachment 22231 Attachment 22232 Attachment 22233 Attachment 22234 Attachment 22235 Attachment 22236 Last edited by snapdragon; 23rd April 2020 at 08:18 AM. |
