Old 5th November 2019, 06:36 AM
carmel120 carmel120 is offline
Default door light strip lighting
Hi im just wondering if anybody has the same trouble as my car the ambient door card strip lighting has a problem on two doors when I change the optic light strip it only goes for about 1 day then goes out again these are used ones that I am using it is annoying in the dark nights now lol.
And what voltage would I see at the optic strip light side so I can check with a meter.
cheers trev
Old 5th November 2019, 01:23 PM
Two of mine (fronts) have blown. Is it a control unit with a LED inside and a fibre optic light pipe or some kind of electroluminescent strip? I forgot all about it not working last time I took door cards off otherwise I would have investigated it. Which part are you replacing? Can it be repaired - maybe a brighter LED or red one would be nicer?
Old 5th November 2019, 04:04 PM
yea it has a separate control box inside the door card that the light strip plugs into not sure what has gone in mine the controller or the optic fibre light strip.
Old 5th November 2019, 05:00 PM
Thanks - is it an electrical connection from the control unit to the door card?
Is there an LED in the strip strip on the door?
Old 5th November 2019, 08:58 PM
yes but its one door loom that does everything on that door.
and no led its like some sort of light ribbon.
