Old 20th November 2019, 11:09 AM
johnny_quattro's Avatar
The semi-rigid cable should be ideal for poking into the scuttle.
Mine certainly exhibited a level of stiffness but required extra reinforcement with some malleable metal wire, something similar to the stuff they use for chain-link fencing. Without that extra assistance, I just couldn't manage to manoeuvre the camera into the required position.
Old 26th November 2019, 11:40 AM
Mine certainly exhibited a level of stiffness but required extra reinforcement with some malleable metal wire, something similar to the stuff they use for chain-link fencing. Without that extra assistance, I just couldn't manage to manoeuvre [the camera] into the required position.
Oo er missus!
Old 26th November 2019, 03:06 PM
Oo er missus!
Don't. I was being really good
Old 27th November 2019, 01:15 PM
Oo er missus!
I was trying to be as descriptive as possible to help HPsauce/Andrew but having read it again, I can see what you mean... I'm just immensely pleased that my mobile bathtub of water is no longer present. I did follow it up with the usual trick of dissolving a dishwasher tablet in a container of hot water to slosh it all through. The endoscope camera was essential, as it was very hard for me to visualise the location of the blocked drain/hole. I'd seen the Paul Waterloo write-up on audipages which gave me a clue but it worked out more difficult in practice.
I've attached a photo taken from the passenger side (NSF) - you can make out the plastic housing at the top (blower/fan/motor sits in here) and the small gap underneath where the water fills up. The drain hole is on the left (to the front of the car) and it glistens due to residual water. Not entirely sure what that sticky-out bolt is for? Let's hope it's watertight as it was submerged as you can see from the original video clip.
Last edited by johnny_quattro; 8th November 2020 at 10:55 AM. Reason: Heinous error - singular, not plural, also OSF incorrect as per The Laird
Old 7th November 2020, 05:00 PM
Default Definition of sadness
Windows covered in condensation?
The definition of sadness must be searching for water ingress on the forums, finding one of your own posts (from almost exactly one year ago, funny that) and then updating your own post after watching your very own inspirational video!
Cheers to Mr Sauce as well for his scuttle drain investigation here: http://forum.a8parts.co.uk/showthread.php?t=12219
It's definitely that time of year.
Old 7th November 2020, 07:23 PM
I've attached a photo taken from the passenger side (OSF) .
Isn’t the passenger side NSF? I’m often wrong, so no hassle if I am again, but I’d appreciate clarification from you guys. Thanks
Old 8th November 2020, 10:54 AM
Yes, you are correct and I'm an idiot! Definitely NSF, I'll see if I can go back and edit the post to clean up. I'm going to take a look at my current issue later today so hopefully I can add some photos.
Old 8th November 2020, 02:54 PM
Usual solution was employed - fill up 2 litre container with hot water, add dishwasher tablet and wait for it to dissolve fully. Fill up a second container with hot water whilst waiting. Added from the NSF (see what I did there, The_Laird) in the gap, and moments later, a pleasing gush of water came out from under the car. It's now clean as a whistle under the bonnet, but after reversing the car (was testing the MJ brake block upgrade), I noticed that water was only vented out of the passenger side. I suspect that I may have to revisit this again.
With the benefit of hindsight, I wish I'd taken the opportunity of snipping off the ends on the fat drainage tubes either side of the flywheel housing when my gearbox was replaced in 2014, if I remember correctly.
Last edited by johnny_quattro; 8th November 2020 at 02:55 PM. Reason: underscore, not a hyphen
Old 9th November 2020, 05:23 PM
Do you add the water through a funnel and tube inserted into the drain, or just pour it into the space below the blower motor?
