Go Back   A8 Parts Forum > A8 D4 > D4 - Common Faults
D4 - Common Faults Quick links to all known common faults and their solutions
Old 26th September 2016, 06:47 PM
The more expensive one is an AGM battery, which is used on stop-start cars. If your current one isn't AGM, I'd stick with the standard type
Old 26th September 2016, 07:10 PM
mondie mondie is offline
The car has start-stop (it's always off though) and I guess has an AGM, all 3 I posted above are AGM although the Varta Silver Dynamic does not promote it. Hence why I am confused, is this all just marketing BS or am I missing something obvious. All of the batterys I have found are slightly smaller in width than the factory battery too.
Old 26th September 2016, 10:43 PM
God this is a ball ache.
From tonight's reading, I have found that to code the new battery to the car you need a battery with a BEM code. Guess who sells them, yep Audi and no one else So screw that.
This is what I will buy tomorrow once I have verified the dims one last time, its the closest I can find to what's in the car.
https://www.tayna.co.uk/610-200-Vart...92--P3200.html
Apparently if you don't recode the car after a new battery 2 things can happen.
1) Possibly shorter battery life but this is probably just a scare from Audi.
2) The cars electrics may not function correctly until the car has learnt that the battery is strong. As mine died overnight I assume the ECU has a stored a depleted battery status and the only way for the car to learn it has a new battery is by using the car, starting it over and over etc so it learns and begins to reactivate systems that are shut down to preserve battery power.
Wonder if that's why you experienced issues with your new battery Peter?
Old 26th September 2016, 10:52 PM
Not sure if your car is the same, but I recently replaced the battery on my RS6 with a non OEM battery, a YUASA one actually. When recoding in the new battery my mechanic was able to use the details of the old OEM battery which it happily accepted, seems as long as it knows it has a new battery it's happy, hope yours is as easy
Old 26th September 2016, 11:21 PM
Brian, yes I read that any details will do provided you can get the car to accept them. Seems like its a load of tosh, resetting the ECU/BCM so it knows it has a new battery is what matters I gather. I guess I will see how I get on without this in a couple of days.
Old 27th September 2016, 07:47 AM
Wonder if that's why you experienced issues with your new battery P̶e̶t̶e̶r̶ Paul?
Exactly that, and that was six months after changing the battery! Net result was things just acted weirdly and the car went into "hibernate" mode far too often. New BCM and new battery and they are hopeful it will be resolved.
Have a read of http://wiki.ross-tech.com/wiki/index...ry_Replacement, the "trick" on the D3 was to use the old battery data but to change the last number of the serial number for the BCM thinks it is actually a "genuine" new battery, not sure if that will work with the D4 though!?
In any case, good luck
Old 27th September 2016, 08:41 AM
six months and still a problem! Hopefully the BCM was the cause of this but what are we coming to when you cannot safely jump a car and need to spend hours learning how to change a battery. Its madness.
If I can get the car going then I will be happy as I can have the car reprogrammed by an Audi specialist next month.
Old 28th September 2016, 09:32 PM
The new battery arrived today from Tanya, £99 delivered. This one:
Fitted it up no problem, case was identical size/shape to the OEM and ratings all within a few percent too. Car started and runs normally, all electrics work normally too, its as though nothing ever happened. So far so good
Thanks for all the advice on this thread.
Old 24th November 2019, 10:01 PM
funkmiester funkmiester is offline
Default Flat battery- car stuck in shut down cycle.
What the hell am i doing on a 3 year old thread? Well it's the same car, I bought from Mondie, last May and it has been brilliant other than getting the rear diff done and some new front discs/pads.
Issue battery is emptying itself in about 5 hours. That's a hell of rate.
Started last week, dead overnight, thought it was unusual but hey, it's winter and was below zero last week.
Charged it back to health off the car. Drained again overnight.
The battery was the one Mondie installed at the end of this thread the silver varta. I was stuck and figured 3 years is a bit short of life so I went round to Halfrauds and bought a 019 AGM 95AH (Halfrauds brand Yausa) for the Ouch of £184 but it has a 5 year guarantee so we'll see.
Knowing what fun coding can be so I bought to a OBDeleven Pro for £99 and have been impressed so far.
What is currently happening with the car is:
Power Off take key out (press the internal alarm off so i can sit in the car and watch)
Powers down as normal then:
Various relays click inside and out (don't know where, traffic noise ouside car)
Parking light red (P) on dash lights with the P on the gear selector and the red parking brake light.
20-30 seconds later
Parking light and gearbox goes out
A pump runs under the bonnet for 20 seconds(don't know what but suspect this is what the big battery drain is)
Then the parking brake light goes out and then 20 seconds later the whole cycle starts again.
Car runs/drives fine, just won't go to sleep.
I did several full dumps with OBD Eleven. I even swapped out the 3 door handle sensors just in case it was that (Mondie had provided replacements but I had never been bothered before, done now, no difference)
Main errors from the dump below:
1) There is also no communication with the Battery control module, either it failed before? or I broke it swapping out the battery (possible but unlikely). I've ordered a new one just in case. And yes the yellow/purplish cable is correctly installed on the negative terminal/BECM
No 19 Gateway has 3
U105000 - Battery monitoring control module No Communication
U104900 - Optical data bus Open circuit
U011200 - Lost Communication With Battery Energy Control Module "B"
static
So I await the new BECM but it might not be that. I know Mondie had the parking brake switch replaced (I have the old one as well) and the fact this weird cycle starts and ends with the parking brake suggests it might be a faulty switch (again). And what is with the optical data bus open circuit?
I'll try disconnecting the parking brake switch tomorrow and see if the cycle continues but I suspect that will just throw up different errors.
Many thanks for reading so far, thoughts welcome.
Here is the full
OBDeleven data log
Date: 2019-11-24 14:15
VIN: WAUZZZ4H2AN003873
Car: Audi A8
Year: 2010
Body type: Saloon
Engine: CDSB 258 kW (351 HP) 4.2 l
Mileage: 132070 KM
01 Engine Control Module 1
System description: 4.2TDI EDC17
Software number: 4H0907409
Software version: 0010
Hardware number: 4H0907409
Hardware version: H04
ODX name: EV_ECM42TDI1114H0907409
ODX version: 001016
Long coding: 0106002C290F0268
Trouble codes:
No trouble codes found
02 Transmission Control Module
System description: 0BL 42 TDIRdW
Software number: 4H1927158Q
Software version: 1008
Hardware number: 0BL927156E
Hardware version: H08
ODX name: EV_TCMALX51011
ODX version: 001013
Long coding: 001111
Trouble codes:
03 Brakes 1
System description: ESP PREMIUM
Software number: 4H0907379A
Software version: 0151
Hardware number: 4H0907379A
Serial number: --------------
ODX name: EV_ESPPremi
ODX version: 004012
Long coding: E4EAA20027574500E300
Trouble codes:
04 Steering Angle Sender
Trouble codes:
05 Kessy
System description: BCM2 2.0
Software number: 4H0907064DB
Software version: 0510
Hardware number: 4H0907064L
Hardware version: H13
Long coding: 05170001000000000000
Subsystems:
System description: FBSAUDID4 IDG
Software number: 4H0959754DD
Software version: 0083
Hardware version: H71
Serial number: 0815000116280013
System description: J764 ELV MLB
Software number: 4H0905852A
Software version: 0042
Hardware version: H37
Serial number: 0210000036533003
Trouble codes:
06 Seat Adjustment Passenger Side
System description: MEM-BFS
Software number: 4H0959760D
Software version: 0115
Hardware number: 4H0959760D
Hardware version: H07
Serial number: 00001010115765
Long coding: 0038320000043201000001010101112131313333283333
Trouble codes:
08 Air Conditioning
System description: Klima 4 Zonen
Software number: 4H0820043D
Software version: 0040
Hardware number: 4H0820043D
Hardware version: H12
ODX name: EV_AirCondiFront
ODX version: 001048
Long coding: 386100BE0C
Trouble codes:
09 Central Electrics
System description: BCM1 2.0
Software number: 4H0907063G
Software version: 0092
Hardware number: 4H0907063
Hardware version: H09
Serial number: 00000000446251
Long coding: 0907201009749FE1AB810007A0001800009DC30A8B00012180 0108542F00
Subsystems:
System description: WWS641 100218
Software number: 4H2955119C
Hardware version: H32
Serial number: 100223010130
Long coding: 0045F7
System description: RLS
Software number: 8K0955559
Software version: 0003
Serial number: 10866911
Long coding: 025D5B
System description: E1 - LDS
Software number: 4H0941531B
Software version: 0044
Serial number: 07 04 2010 00000037
System description: EHL2 V07.03
Software number: 4H0907410
Software version: 0020
Hardware version: H30
Serial number: 0000001805568R05A505
System description: A31 LED Mod1L
Software number: 4H0907472A
Software version: 0002
Hardware version: H01
Serial number: 000000-0000-0000
Long coding: 100000
System description: A27 LED Mod1R
Long coding: 100000
System description: EVLS-SG
Software number: 4H0907705H
Software version: 0275
Serial number: WA091314000000029837
Long coding: 020300
System description: AQ_Hum_Sensor
Software number: 4H0907658
Hardware version: H02
Serial number: F3080B15000000000001
Trouble codes:
10 Parking Assistance 2
System description: PARKHILFE ACC
Software number: 4H0919475C
Software version: 0011
Hardware number: 4H0919475C
Hardware version: H05
Serial number: 44831011006265
ODX name: EV_AU64XParkiAssis2
ODX version: 005003
Long coding: 300902
Trouble codes:
11 Engine Control Module 2
ODX name: EV_ECM42TDI2114H0907409
ODX version: 001016
Trouble codes:
13 Adaptive Cruise Control
System description: ACC3
Software number: 4H0907561A
Software version: 0160
Hardware number: 4H0907561
Hardware version: H15
Serial number: 00000000000000
ODX name: EV_AdaptCruisContrAU64X
ODX version: 001012
Long coding: 3404010201
Trouble codes:
15 Airbag
System description: Airbag10.43
Software number: 4H0959655B
Software version: 0026
Hardware number: 4H0959655B
Hardware version: H22
Serial number: 003G10011PW-
ODX name: EV_AirbaAU10BPAAU64X
ODX version: 001014
Long coding: 30314246304230303037554A305234483053
Trouble codes:
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 4H0953568A
Software version: 0007
Hardware number: 4H0953568A
Serial number: 90815IKQ0000J
Long coding: 0000BC
Subsystems:
System description: E221 - MFL
Software number: 4H0951528
Software version: 0009
Serial number: 01 03 2010 33005292
Trouble codes:
17 Dash Board
System description: TDieGBACC----
Software number: 4H0920950A
Software version: 0185
Hardware number: 4H0920950A
Serial number: 6580305105930160�
ODX name: EV_RBD4K
ODX version: 004033
Long coding: 33060800D7002600010000
Subsystems:
System description: Analoguhr D4
Software number: 4H0919204F
Software version: 0210
Serial number: 1100417001054
Trouble codes:
19 Gateway
System description: J533--Gateway
Software number: 4H0907468F
Software version: 0213
Hardware number: 4H0907468C
Serial number: 00000000014345
ODX name: EV_GatewUDS
ODX version: 001025
Long coding: 00C1037D00
Subsystems:
System description: J367-BDM
Software number: 4H0915181
Software version: 0130
Serial number: 00000000005640101407
Trouble codes:
Intermittent
Date: 2019-11-21 00:33:10
Mileage: 132070 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 248
Voltage terminal 30: 14.5 V
Voltage terminal 15: 14.4 V
Control module temperature: 22 °C
System status: Terminal 15 on
Terminal 15 status: On
Terminal 15 status via CAN: On
IN ZAS_Kl_X: On
Engine running: On
IN ESP_Stillstandsflag: standstill detected
Datenfeld: 0
Intermittent
Date: 2019-11-21 01:12:21
Mileage: 132070 km
Priority: 2
Voltage terminal 30: 11.9 V
Voltage terminal 15: 0.0 V
Control module temperature: 27 °C
System status: Awake_Timer_active
Terminal 15 status: Off
Terminal 15 status via CAN: Off
IN ZAS_Kl_X: Off
Engine running: Off
Datenfeld: 0
static
20 High Beam Assistance
System description: FLA
Software number: 8K0857511E
Software version: 0004
Hardware number: 8K0857511E
Long coding: 04028B646E6E645A5A253D3E
Trouble codes:
22 All Wheel Control
System description: 4 Wheel Drive
Software number: 4H0907163
Software version: 0005
Hardware number: 4H0907163
Hardware version: H11
Serial number: 0012041000010713
ODX name: EV_AllWheelDiffeQSPFR
ODX version: 003017
Trouble codes:
28 Climate Control Unit Rear
System description: Klima Fond
Software number: 4H0919158D
Hardware number: 4H0919158D
ODX name: EV_AirCondiHeck
ODX version: 001038
Long coding: 0800000000
Trouble codes:
30 Special Function 2
System description: STS
Software number: 4H0907440
Hardware number: 4H0907440
Hardware version: H06
Serial number: 00000000003669
Long coding: 01010101000000000000000202
Trouble codes:
34 Ride Control System
System description: LUFE-DAEMPFER
Software number: 4H0907553B
Software version: 0095
Hardware number: 4H0907553
Hardware version: H16
Serial number: �‡0�€
ODX name: EV_AirSuspe
ODX version: 003017
Long coding: 008002
Trouble codes:
36 Seat Adjustment Driver Side
System description: MEM-FS
Serial number: 00001010115805
Long coding: 00383B0000053201000001010101112131313333203333
Trouble codes:
3B Sensor Electronics
System description: SARA 6D red
Software number: 4H0907637A
Software version: 0015
Hardware number: 4H0907637A
Serial number: EJ1BPA37003GK00000000000
ODX name: EV_SARA
ODX version: 006014
Trouble codes:
42 Door Electronics Driver Side
System description: TSG FA
Software number: 4H0959793E
Software version: 0158
Hardware number: 4H0959793E
Serial number: 0000103409803
Long coding: 011F1E215E2162C202000007
Trouble codes:
46 Central Module Comfort System
Serial number: 0129711341
Long coding: 011B0E2200397D85BB2007F28E000000000000000000000000 0000000000
Subsystems:
System description: GTO BF
Software number: 4H0959719
Software version: 0070
Serial number: 00000000000000002453
System description: DWA-Sensor
Software number: 4H0951177
System description: LIN BACKUP HO
Software number: 1K0951605C
Software version: 1501
System description: J245 PS50.028
Software number: 4H0959591
Software version: 0006
Serial number: WOO10009QT$
Long coding: 001F00
System description: J505-FSH
Software number: 4H0907133A
Software version: 0045
Serial number: 00000000000000000477
System description: Dachelektroni
Software number: 4H0947135K
Serial number: A2010000000000073713
Long coding: 010000
System description: V252 PS009
Software number: 4H0959591A
Serial number: WOO10002OWX
Trouble codes:
47 Sound System
System description: BO G3 D4
Software number: 4H0035465A
Software version: 0150
Hardware number: 4H0035465
Serial number: 0010277
Subsystems:
System description: BO D4 SLAVE
Software number: 4H0035466
Software version: 0180
Hardware version: H51
Serial number: 00302100000429
Trouble codes:
52 Door Electronics Passenger Side
System description: TSG BF
Software number: 4H0959792E
Hardware number: 4H0959792E
Serial number: 0000103565148
Trouble codes:
53 Parking Brake
System description: EPB-4
Software number: 4H0907801C
Hardware number: 4H0907801A
Hardware version: H03
Serial number: 00000000001772
ODX name: EV_ParkiBrake
ODX version: 001015
Trouble codes:
56 Radio
System description: Radio U DAB
Software number: 4E0035061L
Software version: 0085
Hardware number: 4E0035061
Hardware version: H46
Serial number: 014CR0A7504809
Long coding: 010103010000000001
Trouble codes:
03455 - Function limitation due to received malfunction value
Intermittent
Priority: 6
Frequency counter: 1
Driving cycle: 248
Mileage: 132070 km
Date: 2019-11-21 00:32:38
57 TV Tuner
System description: HybridTV-DVB
Software number: 4F0919129G
Software version: 0550
Hardware number: 4F0919129
Serial number: 76301300189001
Long coding: 03010000
Trouble codes:
5F Information Control Unit 1
System description: H-BNT-EU
Software number: 4H0035670L
Software version: 0637
Hardware number: 4H0035670
Hardware version: H48
Serial number: 410DV0A7554736
Long coding: 020101000001F9EF6D128B1E00000003000001000000000000
Subsystems:
System description: ECE 2013
Software number: 8R0060884AR
Software version: 1505
System description: DU8 D4 SV NB
Software number: 4H0919604B
Software version: 0021
Hardware version: H44
Serial number: AUZ8ZDA110038WE
System description: E380 BDT D4
Software number: 4H2919600H
Software version: 0065
Serial number: 00000000007461
System description: CD-Database
Software number: 8R0060961
Software version: 1886
Trouble codes:
02067 - Optical data bus unauthorized awakening request
Intermittent
62 Door Electronics Rear Left
System description: TSG HL
Software number: 4H0959795A
Hardware number: 4H0959795A
Serial number: 0000103566105
Long coding: 010F1E21402162C202000007
Trouble codes:
6C Camera System Rear View
System description: SG Rueckfahrkamera
Software number: 4H0907441
Software version: 0030
Hardware number: 4H0907441
Serial number: 525PA8-J03D0D3
Coding: 1022002
Trouble codes:
6D Deck Lid Control Unit
System description: HDSG-Modul
Software number: 4H0959107F
Software version: 0632
Hardware number: 4H0959107F
Serial number: 103000015
ODX name: EV_DeckLidContrUnit
ODX version: 001023
Long coding: 0200044000
Trouble codes:
6F Central Module Comfort System 2
System description: ALM
Software number: 4H0907412
Hardware number: 4H0907412
Serial number: 000000004905
ODX name: EV_Ambie
ODX version: 001008
Long coding: 020000
Trouble codes:
72 Door Electronics Rear Right
System description: TSG HR
Serial number: 0000103566096
Trouble codes:
81 Gear Shift Control Module
System description: GSM-RL
Software number: 4H2927731
Hardware number: 4H2927731
Serial number: SN100317 0079
ODX name: EV_GSM2x3Mono
ODX version: 001017
Trouble codes:
85 On-Board Camera
System description: DPC-SG
Software number: 4H0907217A
Software version: 0016
Hardware number: 4H0907217A
Hardware version: H20
Serial number: 26213002542100000000010089
ODX name: EV_OnBoardCamerDPC
ODX version: 001007
Long coding: E9040000
Trouble codes:
88 Multi Contour Seat Driver Side
System description: IVB
Software number: 4H0907182C
Software version: 0027
Hardware number: 4H0907182C
Serial number: 00449500005501
ODX name: EV_IVBDriveSideFrnt
ODX version: 001003
Long coding: 670FF2
Trouble codes:
89 Multi Contour Seat Passenger Side
Serial number: 00448453180901
ODX name: EV_IVBPasseSideFrnt
ODX version: 001003
Long coding: 270FF2
Trouble codes:
8B Adaptive Cruise Control 2
Software number: 4H0907541A
Hardware number: 4H0907541
ODX name: EV_AdaptCruisContr2AU64X
ODX version: 001010
Trouble codes:
8C Battery Energy Control Module
Trouble codes:
8E Image Processing Electronics
System description: BV-SG
Software number: 4H0907107
Software version: 0008
Hardware number: 4H0907107
Hardware version: H25
Serial number: 00004005190310769100460000
ODX name: EV_BVS
ODX version: 001007
Long coding: 01A28200
Trouble codes:
8F Pretensioner Front Left
System description: RGS-VL
Software number: 4H0980945
Software version: 0060
Hardware number: 4H0980945
ODX name: EV_RGS_L
ODX version: 002006
Long coding: 00660600031F037E000308004248D2000000
Trouble codes:
90 Pretensioner Front Right
System description: RGS-VR
Software number: 4H0980946
Hardware number: 4H0980946
ODX name: EV_RGS_R
ODX version: 002006
Trouble codes:
S8FRD 2002 D2 S8 on LPG 213K just passed MOT, again, no issues. Owned since 2007
**60*** Unicorn, 2012 D4 Havana Black, 4.2TDI ~60K miles Cream Leather, £25K of Factory extras including B+O Owned since 04/2018
Old 24th November 2019, 10:44 PM
20-30 seconds later
Not familiar with the D4 so just guesswork. Before you disconnect the parking brake switch, could you watch it again but with the parking brake not set (assuming the car is parked on a level surface) to see if the behaviour changes. If it does, then the switch would be the culprit.
