Is your RNS-E a MK 1 or 2? If not sure, usually a chrome volume knob and ability to use SDHC cards in the 2 slots behind that are bigger than 4GB is an indicator of Mk2.
I don’t think mk1 supports AMI (Sergey went through all this with his old car) Never seen the iPod dock before!
Here is the RNS-E in my TTS. It has 2 SD card slots, but didn't like the 16GB card that I first tried. It’s fine with 2 GB, non-HC cards
That looks like a Mk2 from the 2 chrome buttons (but they can be swapped)
Was the 16GB card you tried an SDXC? It won't like those, but should accept SDHC. They don't like microSD cards in adaptors either. Worth noting that sometimes SD cards aren't correctly marked for the standard they allegedly comply with - particular problem with 4GB cards (which Mk1 RNS-E needs) as new ones more likely to be SDHC now, but won't necessarily be marked as it. Post a pic of the firmware/map version info too and I can probably go off that too ![]() Shame about the scratches on the screen - it's quite easy to swap them if it annoys you (look at my thread for changing the nav drive unit in the RNS-E and it explains how to strip it down)
The scratches on the screen have mostly come off with a brief wipe with Plastex. I’m sure a more committed session will restore it to its former glory!
You have the last official software release (650) for the first generation of RNS-E unit.
So you're limited to a maximum of 2 x 4GB SD cards (that unit does not support SDHC cards, even 4GB ones) as linked to by briang9 earlier. 2GB (or smaller) SD cards are cheaper and easier to come by, but of course you can't get as many tracks on them. You have the latest maps: 2019 (DD) release. |
There are SD card management utilities you can download to check whether any SD cards you buy are a particular type (SD/HC/XC etc)
I may have some spare 4GB cards from when I had my S8 - will have a look
4GB: Can be either SD or SDHC, but most likely these days SDHC 8GB-32GB: SDHC 64GB and over: SDXC (not compatible with any RNSE) |
