Old 31st January 2020, 12:49 PM
I did have that thought myself Mark, but remember the brake lights are effectively "always live". So I expect it's a safety issue (and maybe even embedded in the regulations somewhere) that brake lights are on a very direct failsafe circuit, hence no relay.
Could you respond to my earlier question:
What sort of symptoms were you getting that made you decide to change the switch, and did you use VCDS to get it set correctly or just judge it by when the brake lights came on?
Old 31st January 2020, 01:41 PM
Sorry, I didn't notice that question.
I had the symptom of restricted power from stand-still, usually at a junction or traffic lights, after I'd been holding the car for a while on the footbrake. There's a hesitation for a few seconds, like the ECU 'thinks' you still have your foot on the brake, which I suspect is the contact sticking.
I also had one or two mysterious ABS faults stored. The first brake switch I had replaced was probably about 8 years ago, so I can't remember if I had the restricted power symptom back then too. It had gone into the garage for some remedial work, which including fixing an intermittent ABS fault. It was the garage who diagnosed the brake switch to be the cause. They were perplexed as to why a brake switch would cause such a fault but a new switch seemed to cure it.
Similar symptoms started appearing again a while ago. This time I replaced the switch myself with a Meyle equivalent. I don't remember having to do any adjustment; I just screwed the switch in. I did check it though, but with my OBDeleven device/app, in which I could see each of the live switching states, much like you can in VCDS.
Old 31st January 2020, 01:55 PM
Cheers Mark, sounds similar enough to my experience to make the same cause/fix plausible.
Though given the way the switch operates, with the released brake pedal arm forcing the spindle of the switch in to disconnect the brake light circuit, it's probably something slightly more complex than contacts sticking.
I'm reluctant to swap the switch in winter weather, easy though that may be in isolation. I don't have a garage/workshop to work in and there's a lot of extra equipment and wiring in and behind the drivers knee cubbyhole and panel that makes removing it non-trivial.
And some of that isn't working properly so if I do go in there I'll be committed to other jobs too: Xcarlink, Bluetooth, DVB-T tuner, receiver for reversing camera radio signal and relays to manage all that without draining the battery.
