Old 3rd February 2020, 04:01 PM
Stromaluski's Avatar
Actually both are blades, see attached photo of a D2 fan connector.
However the male/female setup seems to be reversed, the D2 fan is male whereas the D3 is female, so you couldn't disassemble and reinsert the wires into a different shell even if they were compatible.
D'oh! I remembered that there was a reason I couldn't just re-pin the connector, but I was thinking it was a pin vs blade connector issue. Not a male vs female connector issue. Either way, you have to splice, no matter what.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
