Is the compressor a known good one? The overheating code seems new so could be a faulty compressor.
Most recovery companies will have low flat beds that will recover supercars etc that are very low to the ground
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
![]() This is the airline that goes to the front drivers side strut. |
just to add I assume the compressor shut down to save itself after trying to no avail to inflate the air-strut.
That's what would have caused the 01577 code to be thrown up. |
Correct. It shuts down to save itself however if it has been working hard for a while (every start and driving say) then it can burn out which I gather is what happened to the old one. I wonder if the green pipe was the original culprit?
http://www.air-suspension-shop.com/A...sion-4E0616040 |
**update 04/03/20**
Well I got the car back and the yellow suspension light was on solid. I called Neeldub round who has VCDS and we did a scan clear all the fault codes and did a basic calibration. it seems to have cleared the yellow suspension light. Strangely lift mode is sometimes greyed out and then comes back on again.. Anyone know why this might be? |
Does the lift mode grey out when the car is standing still? It does grey out at a certain speed but shouldn't do at stand still
chaps, can anyone confirm the number for the 30a fuse for the air suspension?
I get part number: 443937105A and this is for a 30a 12v thermal fuse relay. When we speak of replacing the fuse along with the relay can anyone confirm that the above part number is the correct one? It's also green in a silver case 2 pin. see here: https://parts.vw.com/p/Volkswagen__/...43937105A.html |
Do you mean the orange 40A fuse? It's: N 102 519 01
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU |
