I take it you're scanning with something generic and not VCDS?
The transmission output speed sensor to which 'P0721' allegedly refers is inside the gearbox, and it would cause the gearbox to go in to limp mode when in attempting to move in D or R. It would not shut down the engine. Which module are you scanning to find this code? Does the engine start and immediately shut down or does it run until you do something? The usual cause of starting up then immediately shutting down after a couple of seconds is an immobiliser fault. What year is the car? |
Clipped the following from the documentation listed here on the site:
Fault code 17105 / P0721 Display on -VAS 5051- 17105 / P0721 Gearbox output speed sender - G195- Implausible signal Possible cause of fault How to rectify fault ♦ Open circuit or short to earth or – Read measured value block positive in wiring to component 001: With hydraulic control “Type E17” ⇒ page 98 , with hydraulic control “Type E18/2” ⇒ page 112 – Check wiring and connector ac‐ cording to current flow diagram. Also check connector for con‐ tact corrosion or moisture ♦ Gearbox output speed sender - – Perform electrical check, test G195- defective step No. 19 ⇒ page 136 ♦ Screening for gearbox output speed sender -G195- defective ♦ Engine speed signal or gearbox – Rectify fault as described for speed signal incorrect fault code 17100 / P0716 ⇒ page 41 ♦ ATF level not OK – Check ATF level ⇒ Automatic gearbox 01V, front-wheel drive and four-wheel drive; Rep. Gr.
Scanning Engine and TCU...Car will run then just shutting down, bizarre..
All lights coming on the GB gear select panel.. Is pointing at G195 01V927321A which feeds ECU/TCU etc.. Spoke to my Gearbox god here in Cornwall and he also said nothing should shut it down.. Fitted new brake switch and Crank sensor and cleaned up the plugs and contacts around the area. Removed and cleaned the GB sensor in the LH driveshaft output too,,, all good... |
Using genuine VCDS and also Launch X431 Pro V4, all up to date and paid for versions, I own a garage www.ubiquemotordiy.com
Got my auto electrician mate on the case, we have also done lots of checks and replaced the fuel pump relay.. This all started when I flipped from Petrol to LPG and car threw N05 coil pack, which happens every so often.. LPG is not associated to this as its been switched off now and cars still randomly throwing this code as the engine has shut down!! Will check the MBs and see if the sensor loses the signal and then engine shuts down,, hard to diagnose this bugger!! |
As you have already said, the gearbox codes should not shut down the engine. This either suggests you have 2 separate faults with the engine shutting down not logging any codes. So only the gearbox codes are show. Or the fault is affecting 2 separate systems at the same time. Gearbox and engine.
Have you checked for water ingres in the ecu box? Both ecu and tcu are located in the same box. This has happened many times and can be quite a common problem. Have you tried squirting easy start or some similar solution into the inlet whilst trying to start the car? May at least tell you if the engine stopping is fuel or electrical related.
More details might help someone come up with a diagnosis. How long does it run for?When it’s in shut down will it restart straight away? does it take multiple cranks before restart? how much fuel is in it? Can you hear the fuel pump prime at ignition on? Any warning lights? Funny noises? Any other fault codes or just the gearbox one?
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() |
18169 seems to be the bad boy~!!
