It looks like an ordinary speaker screwed in to a bespoke bracket from pictures on Google images. Did you remove the speaker from the door card or just look at the back of it?
It also looks like Audison do a direct drop-in replacement: https://srotas24.co.uk/car-parts/aud...872993648.html |
Thanks for the link and comment, MikkiJayne.
I removed the speaker completely from the door, and the bracket and the speaker housing is made out of one piece of plastic. Although, looking closer at the BOSE speakers, it looks like they are screwed into at separate bracket like those in the Audison link. In the afternoon I received a message from Prestige Motor, that the BOSE speaker will fit directly and will work. He confirmed that they have done it for a customer. Obviously it won't be like a complete BOSE system without the proper amplifier and also the BOSE system has to two speakers in the parcel shelf (and a center treble in the front) that the std sound system doesn't have. I feel tempted to go on with this... ![]()
2006 Audi A8 3.0 TDI Quattro Sport A8 W12/S8 Brakes front and rear (385mm/335mm) Focal and JBL speakers, Helix amps S8 anti-roll bars front and rear Complete rear LED taillight Xenon fog lights All interior LED S8 rims 9x20" Stage II tune S8 Grill |
Not meaning to send the thread OT but does anyone know why the standard door speakers have two input connections and the sound is the same from each?
Phantom Black 2008 A8 3.0 TDI SE ASB |
Talking about speakers, the BOSE set is on the way and have expected arrival on Friday. ![]()
Is one connection the input from the amp and the other the output to the tweeter?
Not for the front doors at least.
Quick update.
The BOSE speakers arrived on friday, and I've done all the doors so far. The swap was as easy as it could be, rip off the door panel, unhook and unscrew the speaker, then screw back on the new speaker, hook it up and attach the door panel. Done in 15 minutes on each door. The tweeters on top of the dash gave me a little bit more work, as the connection plug doesn't fit. Also, I see on the std tweeter there is a 4,7 µF to take away the bass, but there is non on the BOSE speaker. Making med think it could be a crossover hidden somewhere where the cables to the door woofer and the tweeter separates for the BOSE speakers? Well, if so, sending full range to the woofer doesn't matter much but I'm not feeling good about doing the same with the tweeter. There isn't much power in the std amp, but a tweeter is not built to play bass. Another surprise is that using a 4,7 µF together with a 4 ohm tweeter means it will start rolling off at 8k Hz. That is very high roll-off in my opinion, so I think I will use a 10 µF with the BOSE tweeter and see how it sounds. Luckily I have some good quality caps laying around from earlier speaker jobs. And, haven't done anything with the subwoofer yet. Need to see some videos on how to gain access first.
