Old 24th April 2020, 03:26 PM
NightOwl NightOwl is offline
Already got S8 fronts on
Oh ok, then I highly recommend to mount the same in the rear, because now you've already upset the brake bias. I did the S8/W12 brakes on mine a few years ago and did the fronts first and the rear the day after. In between I had a test drive and the balance of the brakes was horrible! The car nose dived heavily under braking and if I used brakes in corners, it under-steered a lot. After finishing both the front and the rear, the brake balance is perfect.
Tip, also change to S8 anti sway bars.
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
