Old 7th May 2020, 08:56 PM
Also worth noting though that Ian mentioned the harness was from a 97 pre-wired car without the solar roof so it seems likely a 95 will already have the wiring
Sorry, missed this.
Yes, a 1995 should have the wiring for the solar roof all pre installed. It will be in the passenger footwell, under the door sill trims somewhere. Really distinct plastic encased cable with a yellow plug that goes nowhere. You will need to remove the upper A pillar trims and feed it up to the sunroof control panel where it belongs...
