Old 15th May 2020, 09:22 AM
I don't know how a D3 works, but the operation of the switch you describe is EXACTLY how it works on a D2, with a very slight gap between the two circuits.
IIRC, in a D2, one is for the brake lights, the other for the ECU.
I suspect the only real difference between the two switches is that yours is the later design with the automatic setting procedure which you have followed.
The D2 version is adjustable on a screw thread, no automatic/ratchet setting to worry about.
