Old 19th May 2020, 05:37 PM
Ronin Ronin is offline
Mine was left like in the first pic, thanks for that link now i know howto fit it properly.
Old 20th May 2020, 12:42 PM
Its the air quality sensor I believe - Used to determine whether or not to auto recirc. It should be sat in the path of the inflowing air to the blower motor....
Old 20th May 2020, 12:51 PM
Ah right, hadn't realised it was just dangling loose when you found it, I assumed you'd released it to look closer.
The mounting isn't the most secure, if the ECU lid has been taken off or not screwed down properly it can just go walkabout.
